Electronics => Electronics => Topic started by: SeagullOne on February 06, 2008, 10:10:29 PM
Okay, I'm planning to use two 8-cell battery packs with 9.6V, wired using a duel parallel adapter to make a 20 Amp hour battery pack for my robot. The problem is I can't seem to find a suitable charger. I'd like to be able to charge the modules at the same time through the parallel adpater, but that would mean I'd have to find a suitable battery charger that can charge up to 16 cells, 9.6V and over 20 amp hour capacity. It looks like this one comes really close: http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2350
It looks like its suitable, except that it can only charge up to 15 cells. I doubt it, but could I use it to safely charge 16 cells?
My next--safer and probably more sensible--option is charging the two 9.6V 10 Amp hour modules separately on this charger, but I'd like it more if I could just nail them both at the same time.
Thanks!
Its a very very bad idea to charge 2 battery packs on the same charger at the same time. If you want to charge them together, you should just buy 2 chargers. Otherwise, you'll run into severe problems.
Gotcha! Won't try it. I'll just charge each pack separately.
Thanks!
Thats why we're here :)
