Electronics => Electronics => Topic started by: digital_pants on July 05, 2010, 10:16:34 AM
hello i seem to have run into a problem. i have bought a sabertooth 2X5 motor driver and i intened to control it using simplified serial in visual basic beacuse it is the language i know the best. i am using a usb to TTL converter to interface the driver with my computer and i have set the dip switches to the correct positions. in VB i have opened the com port for the converter and set the settings for the port. i write the character 127 for full forward and i dont get the desired result........... can anyone help me.
if what i am attempting in my code is completly wrong forgive me, im new :(
to help understand what i am talking about heres some of my code.
Option Explicit On
Imports System.IO.Ports
Public Class Form1
Dim myComPort As New SerialPort
Private Sub btnOn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOn.Click
Dim gogo As Char = "127"
myComPort.Write(gogo)
End Sub
Sub InitializeForm()
Dim bitRates(9) As Integer
Dim nameArray() As String
' Find the COM ports on the system.
nameArray = SerialPort.GetPortNames
Array.Sort(nameArray)
' Fill a combo box with the port names.
cmbPorts.DataSource = nameArray
cmbPorts.DropDownStyle = ComboBoxStyle.DropDownList
' Select a default port.
cmbPorts.SelectedIndex = 1
'Bit rates to select from.
bitRates(0) = 300
bitRates(1) = 600
bitRates(2) = 1200
bitRates(3) = 2400
bitRates(4) = 9600
bitRates(5) = 14400
bitRates(6) = 19200
bitRates(7) = 38400
bitRates(8) = 57600
bitRates(9) = 115200
'Place the bit rates in a combo box.
cmbBitRate.DataSource = bitRates
cmbBitRate.DropDownStyle = ComboBoxStyle.DropDownList
' Select a default bit rate.
cmbBitRate.SelectedItem = 9600
End Sub
Sub OpenComPort()
Try
If Not ComPort.IsOpen Then
ComPort.PortName = cmbPorts.SelectedItem.ToString
' Get the selected bit rate from the combo box.
If cmbBitRate.SelectedIndex > 0 Then
ComPort.BaudRate = CInt(cmbBitRate.SelectedItem)
End If
' Set other port parameters.
ComPort.RtsEnable = True
ComPort.DtrEnable = True
ComPort.Parity = Parity.None
ComPort.DataBits = 8
ComPort.StopBits = StopBits.One
ComPort.Handshake = Handshake.None
ComPort.ReadTimeout = 3000
ComPort.WriteTimeout = 5000
' Open the port.
ComPort.Open()
End If
Catch ex As InvalidOperationException
MessageBox.Show(ex.Message)
Catch ex As UnauthorizedAccessException
Catch ex As System.IO.IOException
End Try
End Sub
This post belongs in Software, NOT Electronics.
my bad. anyway any ideas on my problem.
