Electronics => Electronics => Topic started by: omkar on May 24, 2012, 10:55:54 PM
Hi, I purchased a battery charger as shown in the link below:
http://www.ebay.com.au/itm/320559277083?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (http://www.ebay.com.au/itm/320559277083?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)
I have 12 Nimh 1.2 V 10mAh D-cells:
http://www.ebay.com.au/itm/D-Type-10000mAH-1-2V-Ni-MH-Rechargeable-Battery-Toy-Car-/180559570955?pt=AU_Electronics_Batteries_Chargers&hash=item2a0a30680b (http://www.ebay.com.au/itm/D-Type-10000mAH-1-2V-Ni-MH-Rechargeable-Battery-Toy-Car-/180559570955?pt=AU_Electronics_Batteries_Chargers&hash=item2a0a30680b)
and D-cell holders: http://www.ebay.com.au/itm/5-x-4-D-Cells-Battery-6V-Clip-Holder-Box-Case-w-Lead-1-/200597169212?pt=LH_DefaultDomain_15&hash=item2eb485e43c (http://www.ebay.com.au/itm/5-x-4-D-Cells-Battery-6V-Clip-Holder-Box-Case-w-Lead-1-/200597169212?pt=LH_DefaultDomain_15&hash=item2eb485e43c)
I want to know how to use this charger to charge a battery that will be made up of 10 of these cells clustered using the D-cell holders. Do I just connect the positive and negative of the charger to the positive/negative poles of the battery or do i have to charge each cell individually?
Cheers
Omkar
Charging them all separately would be the best. That would be similar to the balance charging to the LiPo battery. On the other hand, if I were you, I would just charge them all in series like what you are thinking to make things easier.
thanks :) I will post the results soon
You can charge them in series no problem. Individual is more accurate but takes forever. Just use a 1/10 C charge rate and you will be fine. That charger has no thermal sensor so do check on them once in a while to see if they are getting hot. I have a clone of that charger and charge 8644 batteries in series all the time with it along with Lipos.
To anyone reading this post and those who have replied to my original question (thanks by the way :)). This setup worked:
iMax B6 charger set to charge NiMh batteries at 1Amp setting charging 8 1.2V/11000mAh Nimh batteries in series held together in D Cell holders.
I used D Cell holders to hold the cells. As there is no temperature sensor, i kept the whole setup in the middle of my garage away from everything else. But the batteries did not break a sweat. They got slightly luke warm. But when i did this its winter time and my garage is not heated.
Previouslly I tried with 0.3Amp setting and after 14 hrs the batteries were not charged at all. Same with 0.5Amp setting. I think 1/10C (which is 1Amp for a 11000mAh battery) is the minimum setting you need.
Hope this helps whoever tries this.
Cheers
PS: Before putting all 8 cells in series, I checked each one to see if its within +/-10% of each other for voltage output. There were a few which were reading 0.8V, I charged these seperately to bring them up to scratch with the rest of them.
