Electronics => Electronics => Topic started by: Dapallox1 on May 03, 2008, 12:36:44 PM
My RC receiver will only allow 7.2v to the motors and servos. How could I add more voltage just to the motors, say, ten more volts?
Motors or servos? Motors don't work with RC receivers :P
If you want to run high voltage motors with a receiver, you'd need a separate motor driver that interfaces between the receiver and the motor.
For example:
http://www.dimensionengineering.com/Sabertooth2X25.htm
(it can do 24V+)
Many others if you look in the parts list.
Yeah, i forgot about speed controllers. The only problem with that is that hefty price tag! :P A friend and I have a $200 budget to make a 4wd (independent motors), RC bot. It has to be fast and strong (able to navigate through a thick field). Could I build a speed controller like that?
sure u can
what is your level of experience and knowledge in electronics
once we know that we will be able to help you out at a a level that you understand
also ,more details on the robot would be helpful, maximum height, purpose, sensors on it, etc.
If you buy everything ready make not a chance. If you build it yourself, yes you could do it for $200.
what are your motor specs?
