Software => Software => Topic started by: Armouralis on December 26, 2008, 04:00:00 PM
hi i went through the $50 robot tutorial and i am stuck at the programming part.
I am using the AVRISPmkII programmer, and I am having a problem connecting to the circuit. I am using an ATmega168 IC in the circuit and as i am using a breadboard, i checked more than 20 times that all the connections are correct, including the ones that connect to the micro controller..
I went through the programming steps, and when i pluged in the circuit to the programmer, BOTH the green LED's are on. When i try to connect to the circuit (tools>avrprogrammer>conect... or autoconnect), the window pops up after a few seconds saying, "connection failed."
What could be the problem? Both LED's are on, is it because i didnt follow the programming steps correctly, or the chip/ programmer has blow because of a short circuit?
Any Help is appriciated... Thx in advance :(
Have you thoroughly read over this thread?
http://www.societyofrobots.com/robotforum/index.php?topic=1045.0
thx, but i figured it out...
my avr studio had some glitch or something. It stayed in updating mode or something, so once i got the updated version, ir works!!!!
i love the feeling when you work hard on something, then it finally works !!! =]
Too true my friend, too true.
Im glad it worked out for you :)
I am having the same problem. Both green LEDs are lit but AVR Studio reports "connection failed". I have tried all 4 USB ports but it is the same. How exactly was this problem solved?
I had that same issue, It was resolved by downloading the newest version of AVR Studio and updating the firmware of my AVRISP MKII programmer.
Worked like a charm. Thanks a bunch. Now I am on my way to program my first Robot :)
