STAMPY WHEELS
(1/1)
Nate_the_Great:
Hey Admin,
How big are those wheels you used for stampy, they look similar to the Lynxmotion Neoprene Foam Tire, but I can only find ones with a diameter no bigger than 3"  :P . Are your wheels bigger than 3" and if so where did you get them  ???
Thankyou
Admin:
Stampy's wheels are 3.5" diameter.
When using servos, I recommend keeping 3.5" your minimum diameter - 4" would be better. Larger wheels give you higher speeds.
Check here:
http://www.societyofrobots.com/robot_parts_list_wheels.shtml
I got mine from hobby-lobby ages ago. They are foam wheels meant for model RC aircraft.
pomprocker:
Dave Brown R/C airplane wheels - Lite Flite Wheels
http://www.dbproducts.com/store/lfwh.htm - Available either squared off or treaded.
http://www.superdroidrobots.com/shop/item.asp?itemid=106&catid=16
http://www.robotmarketplace.com/products/rc_airplane_wheels.html
Navigation
