autonomous path follower and obstacle avoider
ruffntuff007:
hello friends,
i am making a autonomous path follower and obstacle avoider, i want to use two servo/dc motors for two back weels and want to just attach a caster wheel for front wheet. so having a bot with three wheel , is any problem ?? what type of body should i build ????? ??? ???
airman00:
OK first
what do you mean by path follower? what is the path?
three wheel bot is no problem.
I would recommend using HDPE for the material, buy it from McMaster
also what microcontroller will you be using? and what is your budget
ruffntuff007:
i have 4 friends to contribute. i already have bought a pic development board. going to programme it soon. where can i find hdpe ?
airman00:
--- Quote from: ruffntuff007 on January 15, 2008, 08:34:50 AM ---hello friends,
iam making a path follower and obstacle avoidance system.i am new to robotics, i want to use two dc motors for two rear wheels and a caster wheel in the front.So my bot is having two motors and a caster wheel,total three wheels. Is my idea good enough to proceed ???
--- End quote ---
Don't double post
--- Quote from: ruffntuff007 on January 15, 2008, 08:34:50 AM ---an any one tell me how to connect wheels to a motor ???
--- End quote ---
a regular motor or a servo . And also which exact motor and which exact servo
airman00:
as I said before McMaster.com
Also I would first build the robot and then program it. :P
Also, what is the path that it is following???
Navigation
[#] Next page
