Electronics => Electronics => Topic started by: shadow57 on February 20, 2008, 05:59:15 PM
I'm quite interested in building a robot which can use image processing to help it navigate. I've had a bit of experience with image processing, but I'm not too sure on how to incorporate it into a robot.
My idea is to have a wireless camera mounted on a robot that communicates to my pc, and using a program such as roborealm I can process the images. Then based on these images I could communicate back to the robot via a UART bluetooth link.
Is this a standard way of doing things, or is their a way to connect a camera directly to the microcontroller and communicate with the computer in both directions using UART?
Any tips or suggestions on alternate ways of doing this are welcome :)
Thanks in advance for your help
search google for CMUcam or AVRcam - they connect to the microcontroller directly
though what kind of processing are you planning to do?
Thanks airman.
I did a search for AVRcam and stumbled over this forum post:
http://www.societyofrobots.com/robotforum/index.php?topic=2627.msg22550
The method I was thinking of is like the one suggested in the 2nd post.
The AVRcam looks very impressive... I wouldn't have thought an 8bit microcontroller could handle image processing like that.
I do quite like the idea of being able to watch and record the output of the camera, so needing to be within range of a computer is not a big deal. To start with I'm planning to just do simple colour tracking, but would like to expand into object avoidance and recognition. I suppose roborealm already has a lot of those features built in which might make those things easier.
Does roborealm have features to allow you to send commands over a serial conection?
Yes roborealm does all of that
Download it , and play around -- it is simply amazing!
Also check roborealm's main site , they have a lot of documentation and examples available
Also, with a wireless serial link you can do ALL the processing on the PC - even the robots locomotion processing ( driving around)
Post documentation of your robot on this site when you are done please , ;)
Thanks for your help ;D
I'm very excited about starting on this project! I've got quite a lot of learning ahead of me so it could be some time before I have a functional robot, but when I do I'll be sure to post it on this site :)
