Software => Software => Topic started by: orchid on February 21, 2008, 10:28:11 PM
hi all,
i would like to know if there are somebody use mck2812 (motion control kit)?
can you all help me on how to control the motor using ccs?
need your help
thanks,
be specific about your problem and maybe even those people who dont have that kit can help you out
i dont know how to make the motor to rotate 360 degree. i am using 3 phase brushless dc motor.
Did you read the MCK2812 manual?
Tell us what you already have done, and where you are stuck.
i have read the manual, but i cant really adapt the instruction to my programme because it using assembly language.i am using c code.in the manual, it explain on how to use evaluation programme but when i try to adapt the software into my source code, it didnt work out well. thats make me blur. ???
Can you tell us about your control hardware, and why you are programming using C?
(tell us more about your setup)
do anyone have a source code in c to make the motor rotate 360 degree?
i have try make source code on my own but the motor not spinning. it just move a little, stop, and then the motor start buzzing. why is it my motor not spinning but make sound.what is the cause?do anyone know how to solve the problem?here some of the source code that i have done.{ EvaRegs.ACTRA.all = 0x0000; // all PWM pins forced low initially
if(AdcRegs.ADCRESULT0 > 0x0900 && AdcRegs.ADCRESULT0 < 0x10FF)
GpioDataRegs.GPBDAT.all = 0xFFFB;
EvaRegs.T1PR = 0x03A9;//10kHz
EvaRegs.ACTRA.all = 0x00C2;
// EvaRegs.ACTRA.all = 0x0C02;
// EvaRegs.ACTRA.all = 0x0C20;
// EvaRegs.ACTRA.all = 0x002C;
// EvaRegs.ACTRA.all = 0x020C;
// EvaRegs.ACTRA.all = 0x02C0;
It sounds like a power supply problem - signal is being sent, but not enough power. How are you powering it? Do the batteries need to be recharged?
And don't double post!!!!!
http://www.societyofrobots.com/robotforum/index.php?topic=3273.0
i am using DC power supply to powering it. now i had another problem. the motor is spinning but not quite well.i want to make a variable speed, control the speed using different frequency. the motor is spinning but not as desired. i am using 1kHz, 3 kHz, 5kHz and 7kHz. it is impossible for the wheelchair to move within the range of the frequency?when i run the source code, the motor spinning but for the 3kHz and 5kHz, the motor's rotation is quite mess. can anyone tell me how to convert the speed from frequency to rpm?
thanks
You can't, it's impossible. The reason is because speed is dependent on torque, as well.
If estimation isn't good enough, you will need encoders.
thank you admin.
so , how can i estimate the speed by using the variable frequency?
Experiment, graph the results, and write out an equation that represents the graph line.
Use that equation in code . . .
sorry, i did not get it.
can you explain more about it. i don't know which equation i have to use. The source code that i posted before is the commutation states in 3 phase BLDC motor control. i want to make the motor run in the 3 speed, fast,medium,and slow. to do that, i just change the frequency for the commutation states such as
EvaRegs.T1PR = 0x493E;//1kHz (FAST)
EvaRegs.T1PR = 0x30D4;//3kHz (MEDIUM)
EvaRegs.T1PR = 0x1D4C;//5kHz (SLOW)
EvaRegs.T1PR = 0x14ED;//7kHz (SLOW-STOP)
but the commutation states are still the same.
as a result, the motor run but not as expected. can anyone help me how to fix this problem?
thanks....
open up excel
Send a signal to your motor, measure the speed, record it in excel
Repeat until you have a chart of many speeds vs signal types
Then, using excels' graph function, graph the results using a scatter plot
Then right click the line, and click 'add trendline'. It will give you options on which curve fit you want. Make sure in Options that you select 'Display equation on chart' - that will be your equation which you can put in code.
