Software => Software => Topic started by: SeagullOne on May 20, 2010, 04:15:40 PM
I'm in the process of reprogramming my robot, NINA.
It is programmed using python.
Instead of using Roborealm - as I did for previous versions of my robot - I've decided to switch to OpenCV; I'm pretty impressed, although I still have a lot to learn and it isn't as graphically easy to use.
The objective right now for my robot is this: to detect my face, say hello if greeted, and tell where my face is (left or right of the camera).
I've done a lot of problem solving thus far, but one thing I can't seem to tackle is this: the speech synthesis seems to be delayed or doesn't even occur at all in the programming. The face detection and voice recognition runs just fine, and when the speech synthesis does kick in, it gives the appropriate response. Its just that sometimes the tts, specifically, just won't kick in.
I tested the speech recognition and voice synthesis on its own in a separate .py file, and both speech recognition and text-to-speech run very smoothly. It's just when its accompanied by the vision processing...
The code I'm using is listed below. Basically I modified it from two existing python scripts (one for face detection and the other for speech recognition) and added my own code to it to work for my robotics application. Credits to Michael Gundlac for the speech recognition.
Any idea how I could improve the performance of the voice synthesis? Anything wrong with the software here? Could it possibly be my hardware? I'm using an analogue wireless microphone, a Hercules webcam, python 2.6, OpenCV installed, all on a Dell studio XPS 8100 computer.
import sys
import cv
##################Speech Recogntion and Voice Synthesis#############################
from win32com.client import constants as _constants
import win32com.client
import pythoncom
import time
import thread
# Make sure that we've got our COM wrappers generated.
from win32com.client import gencache
gencache.EnsureModule('{C866CA3A-32F7-11D2-9602-00C04F8EE628}', 0, 5, 0)
_voice = win32com.client.Dispatch("SAPI.SpVoice")
_recognizer = win32com.client.Dispatch("SAPI.SpSharedRecognizer")
_listeners = []
_handlerqueue = []
_eventthread=None
class Listener(object):
"""Listens for speech and calls a callback on a separate thread."""
_all = set()
def __init__(self, context, grammar, callback):
This should never be called directly; use speech.listenfor()
and speech.listenforanything() to create Listener objects.
self._grammar = grammar
Listener._all.add(self)
# Tell event thread to create an event handler to call our callback
# upon hearing speech events
_handlerqueue.append((context, self, callback))
_ensure_event_thread()
def islistening(self):
"""True if this Listener is listening for speech."""
return self in Listener._all
def stoplistening(self):
"""Stop listening for speech. Returns True if we were listening."""
try:
Listener._all.remove(self)
except KeyError:
return False
# This removes all refs to _grammar so the event handler can die
self._grammar = None
if not Listener._all:
global _eventthread
_eventthread = None # Stop the eventthread if it exists
return True
_ListenerBase = win32com.client.getevents("SAPI.SpSharedRecoContext")
class _ListenerCallback(_ListenerBase):
"""Created to fire events upon speech recognition. Instances of this
class automatically die when their listener loses a reference to
its grammar. TODO: we may need to call self.close() to release the
COM object, and we should probably make goaway() a method of self
instead of letting people do it for us.
def __init__(self, oobj, listener, callback):
_ListenerBase.__init__(self, oobj)
self._listener = listener
self._callback = callback
def OnRecognition(self, _1, _2, _3, Result):
# When our listener stops listening, it's supposed to kill this
# object. But COM can be funky, and we may have to call close()
# before the object will die.
if self._listener and not self._listener.islistening():
self.close()
self._listener = None
if self._callback and self._listener:
newResult = win32com.client.Dispatch(Result)
phrase = newResult.PhraseInfo.GetText()
self._callback(phrase, self._listener)
def say(phrase):
"""Say the given phrase out loud."""
_voice.Speak(phrase)
def input(prompt=None, phraselist=None):
Print the prompt if it is not None, then listen for a string in phraselist
(or anything, if phraselist is None.) Returns the string response that is
heard. Note that this will block the thread until a response is heard or
Ctrl-C is pressed.
def response(phrase, listener):
if not hasattr(listener, '_phrase'):
listener._phrase = phrase # so outside caller can find it
listener.stoplistening()
if prompt:
print prompt
if phraselist:
listener = listenfor(phraselist, response)
else:
listener = listenforanything(response)
while listener.islistening():
time.sleep(.1)
return listener._phrase # hacky way to pass back a response...
def stoplistening():
Cause all Listeners to stop listening. Returns True if at least one
Listener was listening.
listeners = set(Listener._all) # clone so stoplistening can pop()
returns = [l.stoplistening() for l in listeners]
return any(returns) # was at least one listening?
def islistening():
"""True if any Listeners are listening."""
return not not Listener._all
def listenforanything(callback):
When anything resembling English is heard, callback(spoken_text, listener)
is executed. Returns a Listener object.
The first argument to callback will be the string of text heard.
The second argument will be the same listener object returned by
listenforanything().
Execution takes place on a single thread shared by all listener callbacks.
return _startlistening(None, callback)
def listenfor(phraselist, callback):
If any of the phrases in the given list are heard,
callback(spoken_text, listener) is executed. Returns a Listener object.
listenfor().
return _startlistening(phraselist, callback)
def _startlistening(phraselist, callback):
Starts listening in Command-and-Control mode if phraselist is
not None, or dictation mode if phraselist is None. When a phrase is
heard, callback(phrase_text, listener) is executed. Returns a
Listener object.
listenfor().
# Make a command-and-control grammar
context = _recognizer.CreateRecoContext()
grammar = context.CreateGrammar()
if phraselist:
grammar.DictationSetState(0)
# dunno why we pass the constants that we do here
rule = grammar.Rules.Add("rule",
_constants.SRATopLevel + _constants.SRADynamic, 0)
rule.Clear()
for phrase in phraselist:
rule.InitialState.AddWordTransition(None, phrase)
# not sure if this is needed - was here before but dupe is below
grammar.Rules.Commit()
# Commit the changes to the grammar
grammar.CmdSetRuleState("rule", 1) # active
else:
grammar.DictationSetState(1)
return Listener(context, grammar, callback)
def _ensure_event_thread():
Make sure the eventthread is running, which checks the handlerqueue
for new eventhandlers to create, and runs the message pump.
global _eventthread
if not _eventthread:
def loop():
while _eventthread:
pythoncom.PumpWaitingMessages()
if _handlerqueue:
(context,listener,callback) = _handlerqueue.pop()
# Just creating a _ListenerCallback object makes events
# fire till listener loses reference to its grammar object
_ListenerCallback(context, listener, callback)
time.sleep(.5)
_eventthread = 1 # so loop doesn't terminate immediately
_eventthread = thread.start_new_thread(loop, ())
##########################Proceed with Vision Algorithms#########################
def detect(image):
image_size = cv.GetSize(image)
# create grayscale version
grayscale = cv.CreateImage(image_size, 8, 1)
cv.CvtColor(image, grayscale, cv.CV_BGR2GRAY)
# create storage
storage = cv.CreateMemStorage(0)
# equalize histogram
cv.EqualizeHist(grayscale, grayscale)
#detect objects
cascade = cv.Load("C:\OpenCV2.1\data\haarcascades\haarcascade_frontalface_default.xml")
global faces
faces = cv.HaarDetectObjects(grayscale, cascade, storage, 1.2, 2, 0, (50, 50))
if faces:
for (x,y,w,h),n in faces:
pt1 = (x,y)
pt2 = (x+w,y+h)
cv.Rectangle(image, pt1, pt2, 255)
def Loc_Callback(phrase, listener):
if phrase == "Where am I":
if faces:
if x >= 140:
say("You are at my right.")
if x <= 120:
say("You are at my left.")
if x >= 121 >=139:
say("You are in front of me.")
if not faces:
say("I can not find you")
if phrase == "Hello Nina":
if faces:
say("Hello")
if not faces:
say("Where are you?")
def listen(Interaction, thread):
listener1 = listenfor(["Where am I", "Hello Nina",], Loc_Callback)
if __name__ == "__main__":
print "Press ESC to exit ..."
# create windows
cv.NamedWindow('Camera')
# create capture device
device = 0 # assume we want first device
capture = cv.CreateCameraCapture(0)
cv.SetCaptureProperty(capture, cv.CV_CAP_PROP_FRAME_WIDTH, 320)
cv.SetCaptureProperty(capture, cv.CV_CAP_PROP_FRAME_HEIGHT, 240)
# check if capture device is OK
if not capture:
print "Error opening capture device"
sys.exit(1)
while 1:
# do forever
thread.start_new_thread(listen, ("speech thread", 2))
# capture the current frame
frame = cv.QueryFrame(capture)
if frame is None:
break
# mirror
cv.Flip(frame, None, 1)
# face detection
detect(frame)
# display webcam image
cv.ShowImage('Camera', frame)
# handle events
k = cv.WaitKey(10)
if k == 0x1b: # ESC
print 'ESC pressed. Exiting ...'
break
Okay I found the problem.
I had to insert a line of code to assert that listener1 was listening. 8)
