Software => Software => Topic started by: sprince09 on March 04, 2009, 09:41:10 PM
Hey guys,
I've been trying to get my Axon to interface with an SDCard (I need to do some data-logging) over the SPI interface. I read through the spi.c and spi.h files included in the latest source code for the Axon and I have been trying to use those functions to interface with my card. Going off of the pin labels in the Axon datasheet and a google search for the pinout of an SDCard, I'm fairly certain that I have my connections set up properly. Anyway, what I've noticed is that whenever I plug in my SDCard, the board resets continually until I remove, which indicates to me that I have a wiring problem somewhere, but I've rebuilt the circuit four times now, and I haven't been able to find any errors with that.
I guess what I'm really interested in knowing is if there are any special considerations I need to make when using SPI on the axon. I noticed that the hardware programmer uses the same pins (except for SS and reset) as SPI does... is there something I should be doing to account for that?
Relevant code that I am running:
void SPITest(void){
rprintfInit(uart1SendByte);
rprintf("\n\r");
spiInit();
rprintf("SPI Interface Successfully Initialized\r\n");
unsigned char a = 0;
while(1){
spiSendByte(a++);//this function blocks until register is cleared (won't clear if nothing is connected?)
rprintf("byte sent: %c \r",a);
Also, when I run the code without the SDCard attached, I get the initialization response over my UART "SPI Interface etc..." and then it blocks at spiSendByte(a++). My understanding of that function is that it will block until the data has been shifted out of the register (can't remember what register off the top of my head). I expected that it will block if the pin is unconnected (maybe I'm wrong).
Anyway, I'd appreciate any insight into this :-\
EDIT: Read my next post!
Alright, after much frustration and self doubt I've figured out what was wrong. I ended up writing my own initialization function:
spi_init(void){
unsigned char a;
//setup pins
#define MISO PB3
#define MOSI PB2
#define SCK PB1
#define SS PB0
DDRB |= (1<<MOSI)|(1<<SCK)|(1<<SS);
DDRB &= ~(1<<MISO);
PORTB |= (1<<SS);//set SS high
PORTB &= ~(1<<MISO);//turn off internal pullup for MISO
PORTB &= ~(1<<MOSI);//pull MOSI low
PORTB &= ~(1<<SCK);//pull SCK low
//setup registers
SPSR = 0b00000000;//see datasheet
SPCR = 0b01010000;//see datasheet
//clear out any junk in SPI buffer
a = SPSR;
And the corresponding function for sending+receiving data:
unsigned char spi_transfer(unsigned char data){
//transmits data over SPI lines and returns the response
SPDR = data;
while(!(SPSR & (1<<SPIF)));//block untill data transmission/reception completes
return SPDR;
It turns out that setting up the software side of the interface wasn't my problem... it was the hardware. The axon_schematic.pdf labels the ISP programming headers (the SPI pins are also the programmer pins) as follows:
Left Right
VTG MISO
RST MOSI
GND SCK
However, the actual layout of the programming pins is:
Left Right
MISO VTG
SCK MOSI
RST GND
;) Works perfect for me now. Hope this helps anyone else who is having issues.
Can you relabel this thread so that anyone searching for this problem in the future has an easier time finding it due to a more descriptive thread subject
Updated
Just wanted to say thanks for this thread. Saved me a whole lot of time figuring out the pinout on the datasheet is wrong!
