Electronics => Electronics => Topic started by: johnnyschelaq on November 30, 2013, 01:04:19 PM
I have a bunch of these motors that I got from an electrician and cant find them anywhere... Does anyone know anything about these???
Maxon Swiss made:
2132.911-11.211-001
Also
960053-0001 04.78
Same motor, these numbers printed on it, looking for some help. Appreciate it!
Pictures?
Dimensions?
I have some Maxon Swiss gearmotors but never found a data sheet on the exact ones. What I suspect is that the ones I have, and maybe the ones you have, were custom order by a manufacturer of some device. These then ended up on the surplus market.
There is a large variety of Maxon motors on Ebay. Did you look there? Does any look like the ones you have?
Maxon (and other motor companies) often make customized versions of their motors for particular use cases.
Maxon is a high-quality brand, so the motors should perform well.
You might want to measure the sizes and diameters, and also the winding resistance, of those motors, and compare to the catalog information for stock Maxon motors, to see what base design of motor you're likely dealing with.
Thanks boys, I will post a pic with dimensions and see if that helps.
My best...
