Software => Software => Topic started by: jkflorek on February 22, 2009, 05:30:22 PM
I wondering if, instead of using delay_cycles() for servo control/delays in the $50 robot, could the_delay_us() and _delay_ms() functions from WinAVR work?
I tried modifying the code, but I haven't received my microcontroller to test it on yet.
Here it is:
SoR_Utils.h
* Copyright (c) 2007 www.societyofrobots.com
* (please link back if you use this code!)
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* Alternatively, this software may be distributed under the terms of BSD
* license.
* SoR Utilities v1, March 10th, 2007
//AVR includes
#include <avr/io.h> // include I/O definitions (port names, pin names, etc)
#include <avr/interrupt.h> // include interrupt support
#include <util/delay.h> // include delay support (in us and ms)
//AVRlib includes
#include "global.h" // include global settings
//#include "buffer.h" // include buffer function library
//#include "uart.h" // include uart function library
//#include "rprintf.h" // include printf function library
//#include "timer.h" // include timer function library (timing, PWM, etc)
#include "a2d.h" // include A/D converter function library
//define port functions; example: PORT_ON( PORTD, 6);
#define PORT_ON( port_letter, number ) port_letter |= (1<<number)
#define PORT_OFF( port_letter, number ) port_letter &= ~(1<<number)
#define PORT_ALL_ON( port_letter, number ) port_letter |= (number)
#define PORT_ALL_OFF( port_letter, number ) port_letter &= ~(number)
#define FLIP_PORT( port_letter, number ) port_letter ^= (1<<number)
#define PORT_IS_ON( port_letter, number ) ( port_letter & (1<<number) )
#define PORT_IS_OFF( port_letter, number ) !( port_letter & (1<<number) )
//************CONFIGURE PORTS************
//configure ports for input or output - specific to ATmega8
void configure_ports(void)
DDRC = 0x00; //configure all C ports for input
PORTC = 0x00; //make sure pull-up resistors are turned off
DDRD = 0xFF; //configure all D ports for output
DDRB = 0xC7; //configure B ports 0, 1, 2, 6, 7 for output (google search '0b11000111 to hex')
//************DELAY FUNCTIONS************
//wait for X amount of cycles (23 cycles is about .992 milliseconds)
//to calculate: 23/.992*(time in milliseconds) = number of cycles
//void delay_cycles(unsigned long int cycles)
// while(cycles > 0)
// cycles--;
//*********SIMPLIFIED FUNCTIONS**********
//functions to make coding easier for a beginner
//but could cause port mixup confusion for intermediate users
void LED_on(void)
PORT_OFF(PORTD, 4);//turn LED on
void LED_off(void)
PORT_ON(PORTD, 4);//turn LED off
void servo_left(signed long int speed)
PORT_ON(PORTD, 0);
_delay_us(speed);
PORT_OFF(PORTD, 0);//keep off
_delay_ms(8);
void servo_right(signed long int speed)
PORT_ON(PORTD, 1);
_delay_us(speed);
PORT_OFF(PORTD, 1);//keep off
_delay_ms(8);
Photovore_v1.c
* license.
* Photovore v1, March 10th, 2007
* Simple case-based method for a robot that chases light.
//SoR Include
#include "SoR_Utils.h" //includes all the technical stuff
int main(void)
//declare variables here
//int i=250;//a 'whatever' variable
int sensor_left=0;//left photoresistor
int sensor_right=0;//right photoresistor
int threshold=8;//the larger this number, the more likely your robot will drive straight
/****************INITIALIZATIONS*******************/
//other stuff Im experimenting with for SoR
//uartInit(); // initialize the UART (serial port)
//uartSetBaudRate(9600);// set the baud rate of the UART for our debug/reporting output
//rprintfInit(uartSendByte);// initialize rprintf system
//timerInit(); // initialize the timer system
configure_ports(); // configure which ports are analog, digital, etc.
a2dInit(); // initialize analog to digital converter (ADC)
a2dSetPrescaler(ADC_PRESCALE_DIV32); // configure ADC scaling
a2dSetReference(ADC_REFERENCE_AVCC); // configure ADC reference voltage
//rprintf("Initialization Complete\r\n");
LED_off();//turn LED on
while(1)
//store sensor data
sensor_left=a2dConvert8bit(5);
sensor_right=a2dConvert8bit(4);
//detects more light on left side of robot
if(sensor_left > sensor_right && (sensor_left - sensor_right) > threshold)
{//go left
servo_left(1750);
servo_right(1750);
//detects more light on right side of robot
else if(sensor_right > sensor_left && (sensor_right - sensor_left) > threshold)
{//go right
servo_left(1250);
servo_right(1250);
//light is about equal on both sides
else
{//go straight
servo_left(1250);
servo_right(1750);
/* Servo Test Code
i=250;
while(i>0)
servo_left(40);
i--;
i=250;
while(i>0)
servo_left(24);
i--;
//output message to serial (use hyperterminal)
//print("Hello, World! Read My Analog: %u\r\n", sensor_0);
_delay_ms(20);//a small delay to prevent crazy oscillations
return 0;
/*********************COMMAND LIST*************************
delay_cycles(cycles);
Delays - you can make your robot wait for a certain amount of time with this function.
Put the number of computational cycles to delay in the ().
to calculate: 23/.992*(time in milliseconds to delay) = cycles
Check servo datasheet where it says: 'Direction: Clockwise/Pulse Traveling 1500 to 1900usec'
servo_left(speed); and servo_right(speed);
Commands your servos to rotate at a certain speed.
Vary speed (which represents a delay in cycles) from 20 to 50.
Left is for port D0 and right is for port D1.
LED_on(); and LED_off();
Turns on and off your LED. The LED is on port D4.
By bringing port D4 low, you are turning on the LED.
variable=a2dConvert8bit(pin);
Reads analog pin. For example, set 'pin' to 5 to read PC5.
'variable' will store the value.
It's probably a matter of resolution. You can't delay less then one cycle and this:
... tells you you're working with an pretty slow MCU: .992/23 ~= 0.043 ms per clock cycle, and that's ~= 43 us per clock cycle; This makes the _delay_us() pretty unusefull because it will round everything to 43 us anyway, probably more because of the inherent lost cycles: remamber an cycle is 43 us!
If you'd hook up an oscillator to that MCU you might get better use out of the _delay_us() and _delay_ms() functions but as things are it's probably better to simply use the delay_cycles routine, it's closer to what's actually happening.
The delay_us() and delay_ms() functions for AVR Lib C (not WinAVR) also use cycles. You define clock rate, and it automatically calculates required cycles for you. However their method introduces rounding errors that I didn't like. You can use either method as all code comes with the $50 Robot.
