Software => Software => Topic started by: robota on February 10, 2009, 06:31:05 PM
Hallow friends
I am new with labview
I want to learn how I control an encoder with labview
Tanks
usually encoders get hooked up with a motor and the signal goes to an MCU. I don't know of any labview compilers for an MCU.
LabView lets you hook up devices called a DAQ, of which has lots of I/O to do stuff with.
You could also just you any microcontroller and have LabView read in data that you send it. (a DAQ has a built in microcontroller)
you can use the encoder with the labVIEw , through DAQ you need to use the DAQmx from the Block Diagram on the LabVIEW then choose acquiring signals, then select count edges and connect it from the DAQ...
I search after more forums that have people that know labview
Also I search after people around all the world that teach labview
I search after names of books that explain How to program things that related to robotics in labview software
