Mechanics and Construction => Mechanics and Construction => Topic started by: xaockhaos on February 09, 2013, 04:44:06 PM
A few questions to lead to the ultimate answer for the above question
What type of robot would it look like ?
How complicated will be robot be ?
Does it open up possibility to evolve robot like biological creature ? (Darwin evolutionary theory survival of the fittest )
What would be the end point of the robot after evolving using the basis as survival =able to collect energy on its own ?
Suggestion to implement self assemble robot ?
Try to tackle the problem using different perspective
- Mechanical approach
- Theoretical approach
- Biological approach
- or any type of approach
Would reveal the answers after 10 suggestion :P
Is this Your homework? ;D
It would look the way You want it to look. If You build a robot, You decide upon its looks and functionality (which would influence looks).
As complicated as You want it to be, or as complicated to successfully perform given task.
It does not as to achieve that robot has to be able to think and we all know that true artificial intelligence does not exist :)
To start with, robots cannot "evolve" by themselves as they do not posses true artificial intelligence, hence no cognitive thinking. They cannot set own goals apart from the ones that are set for them by humans.
"Self assembling robot" and "evolution able robot" may be very different things. "Self assembling robot" can be simple ABB robotic arm assembling other ABB robotic arms, or it can be a robot with some clever algorithms which identify broken parts and actuate robot in proper sequence to obtain new part from the stock-room and replace the broken one with it. If, however, You are talking about "Matrix"-like robots - they are only Sci-Fi yet (if possible at all).
How to assemble a robot using the same robot ?
You need to create robot first in order for it to perform something, as soon as it completes the job - it stops, unless further instructions are given. Robot cannot build itself from noting, there has to be a starting point. Even for such advanced organisms like humans - it takes 2 to make 1. And even if scientist come up with some synthetic cell based materials for robots which would be able to split and grow colonies the same way Your flesh does - robots would still lack human-like dreams to motivate them to do something apart from what's been told for them to do.
