Software > Software
wall following robot using analog distance sharp sensor
otai92:
tq :) . I know the sensor have range of detection, if out from the range, sensor cant work properly. I think my problem is my programming .
this is simple programming i give
#define suis1 PORTB.F0
///////output////////////
#define led1 PORTB.F6
#define led2 PORTB.F7
#define motold PORTC.F4
#define motolb PORTC.F5
#define motord PORTC.F6
#define motorb PORTC.F7
#define speedr CCPR1L
#define speedl CCPR2L
// Lcd pinout settings
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
// Pin direction
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
///////////define funtion///////////
void mula();
void adc0_display ();
void adc2_display ();
void depan(int l,int r);
void kanan(int l,int r);
void kiri(int l,int r);
//void pusing_kiri();
//void pusing_kanan();
void wallfollow();
void stop();
//////intial variable///////
int ADC_Value0,ADC_VaLue2,ad1,ad2,ad3,ad4;
int ad5,ad6,ad7,ad8;
void main()
mula();
Lcd_Init(); // Initialize LCD
Lcd_cmd(_LCD_CURSOR_OFF);
lcd_out(1,1,"miroc");
delay_ms(1000);
Lcd_Cmd(_LCD_CLEAR);
lcd_out(1,1,"ad1=");
lcd_out(2,1,"ad2=");
while(1) //infinate loop
adc0_display ();
adc2_display ();
if(suis1==0)
while(1)
if(ADC_Read(0)==ADC_Read(2))
while(ADC_Read(0)==ADC_Read(2))
led1=led2=1;
forward(250,230);
else if((ADC_Read(0)>40)&&(ADC_Read(2)<40))
while((ADC_Read(0)>40)&&(ADC_Read(2)<40))
led1=1;
left(180,200);
else if ((ADC_Read(0)<40)&&(ADC_Read(2)>40))
while ((ADC_Read(0)<40)&&(ADC_Read(2)>40))
led2=1;
right(200,180);
else
led1=led2=1;
foward(250,230);
void mula()
TRISA=0b000000111; // define input or output
TRISB=0b000000001;
TRISC=0b000000000;
TRISD=0b000000000;
TRISE=0b000000000;
ADCON1=0b000000000; // set input PORTA become become analog
PR2=255;
CCP1CON = 0b00001100; //to generate PWM @ ccp1 and ccp2
CCP2CON = 0b00001100;
T2CON = 0b00000110; //on timer 2 to power up PWM
speedl=speedr=0;
motord=0;
motorb=0;
motold=0;
motolb=0;
led1=led2=0;
ADC_Value0= ADC_Read(0);
ad1=ADC_value0/1000 +48;
lcd_chr(1,5,ad1);
ADC_value0%=1000;
ad2=ADC_value0/100 +48;
lcd_chr(1,6,ad2);
ADC_Value0%=100;
ad3=ADC_value0/10 +48;
lcd_chr(1,7,ad3);
ADC_Value2= ADC_Read(2);
ad5=ADC_value2/1000 +48;
lcd_chr(2,5,ad5);
ADC_value2%=1000;
ad6=ADC_value2/100 +48;
lcd_chr(2,6,ad6);
ADC_Value2%=100;
ad7=ADC_value2/10 +48;
lcd_chr(2,7,ad7);
void foward(int l,int r)
motord=1;
motorb=0;
speedr=r;
motold=1;
motolb=0;
speedl=l;
void right(int l,int r)
motorb=1;
motord=0;
speedr=r;
motold=1;
motolb=0;
speedl=l;
void left(int l,int r)
motord=1;
motorb=0;
speedr=r;
motolb=1;
motold=0;
speedl=l;
void stop ()
motord=0;
motolb=0;
speedl=0;
speedr=0;
can you all give me simple coding that you did it for wall follow robot using that sensor or give me the best link/website for wall follow robot programming . Thank you again to waltr and jkerns because your relpy :) .
Navigation
[*] Previous page
