Electronics => Electronics => Topic started by: Matt4328 on February 03, 2014, 09:34:29 AM
I need the advice of a professional. I have a design at the moment (it's somewhere between Johnny 5 and darwin). My biggest problem is going to be battery power. Do you think it would be possible to wire a "wind up torch" powered by a dc motor to recharge batteries.
With use of a voltage tester I hope to be able to control the dc motor to cut off.
Thank you
With the correct voltages, yes, you can charge batteries using any power source, be it a wind-up-torch or solar cell.
In general, you'll need an efficient switching DC/DC converter to generate the appropriate input voltage from whatever your power source is.
Also, if the batteries are Lithium-based, you need a battery management circuit to avoid over-charging (and over-discharging) as well as balancing if you have multiple cells.
Thank you
The problem is that you just can't generate much power with a small hand crank. And then you have the problem of converting the voltage it does make to hat the battery needs.
That can be compensated by using a longer charging (and cranking) time.
... and a longer crank handle :)
(and correspondingly heavier generator load)
