Software => Software => Topic started by: jzaun on March 29, 2012, 02:40:46 PM
Title: Axon2 - first steps at MCU programming. Uart question
Post by: jzaun on March 29, 2012, 02:40:46 PM
Hi all.
I got my toolchain all setup and can compile and load a program onto my AxonII. I've managed to get a led to blink so I'm happy so far. the next thing I'm trying to do is get some output back to my computer over the usb port. I'm trying to code up the uart to do this but am running into problems. I'm not getting anything sent, not even garbage.
If someone would take a moment to look over my code and tell me what I'm doing wrong I would greatly appreciate it. I'm sure I'm doing a lot wrong :)
uart.c:
#include <inttypes.h>
#include <avr/io.h>
void uartInit(uint8_t uart, uint32_t baud)
    switch (uart) {
        case 0:
            // Set baud rate
            UBRR0H = (uint8_t)(((F_CPU/(baud<<4))-1)>>8);
            UBRR0L = (uint8_t)((F_CPU/(baud<<4))-1);
            // Set frame format to 8 data bits, no parity, 1 stop bit
            UCSR0C = (3<<UCSZ00);
            // Enable receiver and transmitter
            UCSR0B = (1<<RXEN0)|(1<<TXEN0);
            break;
        case 1:
            // Set baud rate
            UBRR1H = (uint8_t)(((F_CPU/(baud<<4))-1)>>8);
            UBRR1L = (uint8_t)((F_CPU/(baud<<4))-1);
            UCSR1C = (3<<UCSZ00);
            UCSR1B = (1<<RXEN1)|(1<<TXEN1);
            break;
        case 2:
            // Set baud rate
            UBRR2H = (uint8_t)(((F_CPU/(baud<<4))-1)>>8);
            UBRR2L = (uint8_t)((F_CPU/(baud<<4))-1);
            UCSR2C = (3<<UCSZ00);
            UCSR2B = (1<<RXEN2)|(1<<TXEN2);
            break;
        case 3:
            // Set baud rate
            UBRR3H = (uint8_t)(((F_CPU/(baud<<4))-1)>>8);
            UBRR3L = (uint8_t)((F_CPU/(baud<<4))-1);
            UCSR3C = (3<<UCSZ00);
            UCSR3B = (1<<RXEN3)|(1<<TXEN3);
            break;
        default:
            break;
void uartSendByte(uint8_t uart, uint8_t u8Data)
    switch (uart) {
        case 0:
            // Wait if a byte is being transmitted
            while((UCSR0A&(1<<UDRE0)) == 0);
            // Transmit data
            UDR0 = u8Data;
            break;
        case 1:
            while((UCSR1A&(1<<UDRE1)) == 0);
            // Transmit data
            UDR1 = u8Data;
            break;
        case 2:
            while((UCSR2A&(1<<UDRE2)) == 0);
            // Transmit data
            UDR2 = u8Data;
            break;
        case 3:
            while((UCSR3A&(1<<UDRE3)) == 0);
            // Transmit data
            UDR3 = u8Data;
            break;
        default:
            break;
uint8_t uartRecvByte(uint8_t uart)
    switch (uart) {
        case 0:
            // Wait until a byte has been received
            while((UCSR0A&(1<<RXC0)) == 0);
            // Return received data
            return UDR0;
            break;
        case 1:
            while((UCSR1A&(1<<RXC1)) == 0);
            return UDR1;
            break;
        case 2:
            while((UCSR2A&(1<<RXC2)) == 0);
            return UDR2;
            break;
        case 3:
            while((UCSR3A&(1<<RXC3)) == 0);
            return UDR3;
            break;
        default:
            break;
    return 0;
main.c:
#include <avr/io.h>
#include <avr/interrupt.h>
#include "board.h"
#include "uart.h"
int main(void) {
initBoard();
    // Setup the clock
    cli();                          // Disable global interrupts
    TCCR1B |= 1<<CS11 | 1<<CS10;    // Divide by 64
    OCR1A = 15624;                  // Count 15624 cycles for 1 second interrupt
    TCCR1B |= 1<<WGM12;             // Put Timer/Counter1 in CTC mode
    TIMSK1 |= 1<<OCIE1A;            // Enable timer compare interrupt
    sei();                          // Enable global interrupts
    uint8_t uart = 1;
    uartInit(uart, 9600);
    uartSendByte(uart, '.');
    char data = 0;
    while(1)
        data = uartRecvByte(uart);
        uartSendByte(uart, '[');
        uartSendByte(uart, data);
        uartSendByte(uart, ']');
// Interrupt Service Routine
ISR(TIMER1_COMPA_vect)
    PORTC ^= (1<<3);
I'm really just looking to get a echo back of what I send. I know I'm not using interrupts for the uart and its not buffered or anything fancy, but I have to start someplace :)
I had an dumb error in my code. This seems to be working now. Still any comments or suggestions for a beginner.
Title: Re: Axon2 - first steps at MCU programming. Uart question
Post by: Gertlex on March 29, 2012, 05:47:22 PM
I'd give you a hand if I could remember off-hand, but rather than doing stuff from scratch, I use WebbotLib + Project Designer (http://webbot.org.uk/iPoint/30.page) to generate my projects (and it includes examples for whatever hardware I'm including), and then I do the coding from there.
This is just a recommendation; Some folks on here will certainly be able to help if you want to go the scratch route :)
Post by: jzaun on March 29, 2012, 09:50:30 PM
I would love to but I'm on a mac and there are issued with webbotlib and the designer.
Post by: Admin on March 29, 2012, 11:36:18 PM
Can you tell us more about the mac problem you are having? It should work . . .
My old Axon code didn't use WebbotLib:
http://www.societyofrobots.com/axon/downloads/Axon_Source_102009.zip (http://www.societyofrobots.com/axon/downloads/Axon_Source_102009.zip)
It'll work just fine with the Axon II, but some of the digital I/O changed so you'll need to update the utils file.
You can also copy/paste the UART code from it.
Post by: jzaun on March 30, 2012, 12:33:16 AM
Thanks Admin.
I sent you a PM but got an error so not sure if it went through.
Post by: Webbot on March 31, 2012, 09:26:05 AM
Like what?
