Mechanics and Construction => Mechanics and Construction => Topic started by: tjump on January 31, 2009, 01:30:42 PM
I'm throwing out some calculations to see if we are on target or have missed something.
We have a 10in arm that we are designing to lift 60lbs. The arm is driven by a 2in sprocket. The 2in sprocket is driven by a 1in sprocket (chain linking the two sprockets). The 1in sprocket is attached to the 3/8in output shaft of the motor.
What torque do we need out of the motor?
Using simple MA calculations and ignoring efficiency we have arrived at a value of approx. 160 in lbs.
Below is our calculation process
output lever has MA of 1:10 (radius of sprocket at 1" to length of arm at 10")
pulley system has MA of 2:1 (diameter of input sprocket at 1", diameter at output sprocket at 2in)
motor shaft to sprocket has MA of 3:8 (radius of motor shaft at 3/16in, radius of sprocket at 1/2in)
This gives us 800lbs at the edge of the motor shaft (3/16in radius) and thus at 1in out from the center of rotation of the motor shaft would be approximately 1/5 of this (3*5 = 15, ergo 15/16in) or 160 in lbs.
I would appreciate confirmation or corrections.
You're thinking into this too much. The torque required by the motor is simply (60 * 10) * (1 / 2) = 300 lbf-in.
You should draw a FBD, it'll be obvious when you do.
Also, you can ignore all those gearing ratios and just use the motor shaft sprocket and main arm sprocket ratio.
correct
