Electronics => Electronics => Topic started by: prasanth301 on March 20, 2008, 12:25:21 AM
can any one post the pin diagram of the ic used for line following robot and please specify the pin details i.e this pin is for motor 1, some thing like that
plzz post clearly .. what do u mean bt ic for line following ???motor, sensor, microcontroller???
which line following robot?
pin diagram of ATmega32
which line following robot exactly?
The pin diagram of teh ATmega32 can be found by searching google
(http://www.mcu.hk/GIF/ATmega32.gif)
you mean the $50 robot line folower mod. or the $40 robot?
he means the motor pin diagram of the l293d well look for the datasheet evrything is in that
i need something similer to this for ATmega 32
(http://www.kmitl.ac.th/~kswichit/LFrobot/Pbotcircuit.gif)
u should say schematic not pin diagram ok try to google it and write something like this
schematic for line follower using atmega32
but i would suggest try making ur own circuit
The topicstarter didn't know the difference between a pin diagram and a schematic, I doubt he's able to design his own schematic.
No offense.
ontopic:
search the forum and google before you start a topic.
or read a datasheet.
which instructions are you following?
or are you making your own from scratch?
well as i told bfore try googling
Why ATmega32?
I think you'd be better if you just did this:
http://www.societyofrobots.com/step_by_step_robot.shtml
or this:
http://www.societyofrobots.com/member_tutorials/node/59
