Mechanics and Construction => Mechanics and Construction => Topic started by: lemontree on December 01, 2009, 09:35:08 PM
I am kind of interested in powering a linear actuator using internal combustion. I haven't found much on the internet about that. Sometimes if you don't know the right keywords you don't get any worthwhile results. I once went looking for blank pcb material, and found next to nothing. If you search using copper laminate you'll find plenty. Any ideas?
I would attach a model airplane internal combustion engine to a gear box
and the gear shaft to a long threaded rod with a matching nut soldered at the end
of a copper plumbing pipe with a slightly larger internal diameter to fit over the threaded rod.
Reverse would be a problem, unless the gear box had an electro-mechanical gear swap for reverse.
On the other, a long piston, slow, Stirling engine could do push-pull. That is not internal combustion.
It is external.
Maybe the egg suction technique could be used: That is internal combustion.
Egg Suction Into Bottle Experiment (http://www.youtube.com/watch?v=Qb8xEo1kZUw#)
Your idea reminded me of a Myth Buster's episode where they tried to reproduce engines that ran on blackpower.
My idea was to use an electric solenoid to compress a mixture of air and butane up to its auto ignition point. Then let the combustion products expand against a piston (ie the solenoid core) and extract work from the linear motion. Maybe for a jumping robot or you can generate electricity from linear motion.
I guess it not possible to do that in a very simple way, or at least you would need some electrically actuated valves and things.
Look up SPUD guns, Potato Guns and Pumpkin guns. These all operate under the principle of expanding gas (burning butane or propane and air) to push a piston (spud).
Just be careful with your experiments as we do want you to be able to report back.
