Software => Software => Topic started by: benji on November 10, 2007, 04:34:55 PM
I need to send data from my PC to the hooked avr through serial port,
how do i make a c or visual c++ program on a pc to send/recieve data to/from the avr?
(i totaly know how to program the avr USART, my problem is on the PC side )
thanks already for any help
I recently had a c# data logging project...
http://msmvps.com/blogs/coad/archive/2005/03/23/SerialPort-_2800_RS_2D00_232-Serial-COM-Port_2900_-in-C_2300_-.NET.aspx
You can get free .Net Express stuff here:
http://msdn2.microsoft.com/en-us/express/default.aspx
I prefer Linux however and some other people might too. If some one is looking for a good example of that, here is a good example that I've used often for reference:
* Copyright (c) 2006 Dave Hylands
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* Alternatively, this software may be distributed under the terms of BSD
* license.
* See README and COPYING for more details.
* sertest.c
* PURPOSE:
* This implements a sample program for accessing the serial port.
/* ---- Include Files ---------------------------------------------------- */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/unistd.h>
#include <pthread.h>
#include <getopt.h>
#include <termios.h>
/* ---- Public Variables ------------------------------------------------- */
int gFd = -1;
int gVal;
/* ---- Private Constants and Types -------------------------------------- */
/* ---- Private Variables ------------------------------------------------ */
struct option gLongOption[] =
// option A Flag V (has_arg, flag, val)
{ "baud", 1, NULL, 'b' },
{ "debug", 0, NULL, 'd' },
{ "help", 0, NULL, 'h' },
{ "port", 1, NULL, 'p' },
{ "verbose", 0, NULL, 'v' },
{ 0 },
struct
speed_t speed;
unsigned baudRate;
} gBaudTable[] =
{ B50, 50 },
{ B75, 75 },
{ B110, 110 },
{ B134, 134 },
{ B150, 150 },
{ B200, 200 },
{ B300, 300 },
{ B600, 600 },
{ B1200, 1200 },
{ B1800, 1800 },
{ B2400, 2400 },
{ B4800, 4800 },
{ B9600, 9600 },
{ B19200, 19200 },
{ B38400, 38400 },
{ B57600, 57600 },
{ B115200, 115200 },
{ B230400, 230400 }
#define ARRAY_LEN(x) ( sizeof( x ) / sizeof( x[ 0 ]))
int gVerbose = 0;
int gDebug = 0;
int gPortFd = -1;
/* ---- Private Function Prototypes -------------------------------------- */
void *ReaderThread( void *param );
char *StrMaxCpy( char *dst, const char *src, size_t maxLen );
char *StrMaxCat( char *dst, const char *src, size_t maxLen );
void Usage( void );
/* ---- Functions -------------------------------------------------------- */
* main
int main( int argc, char **argv )
int rc;
int opt;
char devName[ 40 ];
const char *baudStr = NULL;
const char *portStr = "ttyS2";
speed_t baudRate;
pthread_t readerThreadId;
struct termios attr;
// Parse the command line options
while (( opt = getopt_long( argc, argv, "b:dhp:v", gLongOption, NULL )) > 0 )
switch ( opt )
case 'b':
baudStr = optarg;
break;
case 'd':
gDebug = 1;
break;
case 'p':
portStr = optarg;
break;
case 'v':
gVerbose = 1;
break;
case '?':
case 'h':
Usage();
return 1;
devName[ 0 ] = '\0';
if ( portStr[ 0 ] != '/' )
StrMaxCpy( devName, "/dev/", sizeof( devName ));
StrMaxCat( devName, portStr, sizeof( devName ));
baudRate = B0;
if ( baudStr == NULL )
baudRate = B9600;
else
int baudIdx;
int testBaud = atoi( baudStr );
for ( baudIdx = 0; baudIdx < ARRAY_LEN( gBaudTable ); baudIdx++ )
if ( gBaudTable[ baudIdx ].baudRate == testBaud )
baudRate = gBaudTable[ baudIdx ].speed;
break;
if ( baudRate == B0 )
fprintf( stderr, "Unrecognized baud rate: '%s'\n", baudStr );
exit( 1 );
if (( gPortFd = open( devName, O_RDWR | O_EXCL )) < 0 )
fprintf( stderr, "Unable to open serial port '%s': %s\n", devName, strerror( errno ));
exit( 2 );
if ( tcgetattr( gPortFd, &attr ) < 0 )
fprintf( stderr, "Call to tcgetattr failed: %s\n", strerror( errno ));
exit( 3 );
attr.c_iflag = 0;
attr.c_oflag = 0;
attr.c_cflag = CLOCAL | CREAD | CS8;
attr.c_lflag = 0;
attr.c_cc[ VTIME ] = 0; // timeout in tenths of a second
attr.c_cc[ VMIN ] = 1; // Only wait for a single char
cfsetispeed( &attr, baudRate );
cfsetospeed( &attr, baudRate );
if ( tcsetattr( gPortFd, TCSAFLUSH, &attr ) < 0 )
fprintf( stderr, "Call to tcsetattr failed: %s\n", strerror( errno ));
exit( 4 );
// Put stdin & stdout in unbuffered mode.
setbuf( stdin, NULL );
setbuf( stdout, NULL );
// Put stdin in raw mode (i.e. turn off canonical mode). Canonical mode
// causes the driver to wait for the RETURN character so that line editing
// can take place. We also want to turn off ECHO.
struct termios tio;
if ( tcgetattr( fileno( stdin ), &tio ) < 0 )
fprintf( stderr, "Unable to retrieve terminal settings: %s\n", strerror( errno ));
exit( 5 );
tio.c_lflag &= ~( ICANON | ECHO );
tio.c_cc[VTIME] = 0;
tio.c_cc[VMIN] = 1;
if ( tcsetattr( fileno( stdin ), TCSANOW, &tio ) < 0 )
fprintf( stderr, "Unable to update terminal settings: %s\n", strerror( errno ));
exit( 6 );
// Kick off the serial port reader thread.
rc = pthread_create( &readerThreadId, NULL, ReaderThread, NULL );
if ( rc != 0 )
fprintf( stderr, "Error creating ReaderThread: %s\n", strerror( rc ));
exit( 7 );
// Read stdin and send rcvd chars to the serial port
while ( 1 )
char ch;
int chInt = fgetc( stdin );
if ( chInt < 0 )
fprintf( stderr, "Exiting...\n" );
break;
ch = (char)chInt;
if ( gDebug )
if (( ch < ' ' ) || ( ch > '~' ))
fprintf( stderr, "stdin Read: 0x%02x '.'\n", ch );
else
fprintf( stderr, "stdin Read: 0x%02x '%c'\n", ch, ch );
if ( write( gPortFd, &ch, 1 ) != 1 )
fprintf( stderr, "write to serial port failed: %s\n", strerror( errno ));
break;
close( gPortFd );
exit( 0 );
return 0; // Get rid of warning about not returning anything
* Thread which processes the incoming serial data.
while ( 1 )
char ch;
int bytesRead;
if (( bytesRead = read( gPortFd, &ch, 1 )) < 0 )
fprintf( stderr, "Serial port read failed: %s\n", strerror( errno ));
exit( 1 );
if ( gDebug )
fprintf( stderr, "Serial Read: 0x%02x '.'\n", ch );
else
fprintf( stderr, "Serial Read: 0x%02x '%c'\n", ch, ch );
putc( ch, stdout );
return 0;
} // ReaderThread
* Concatenates source to the destination, but makes sure that the
* destination string (including terminating null), doesn't exceed maxLen.
* @param dst (mod) String to concatnate onto.
* @param src (in) String to being added to the end of @a dst.
* @param maxLen (in) Maximum length that @a dst is allowed to be.
* @return A pointer to the destination string.
size_t dstLen = strlen( dst );
if ( dstLen < maxLen )
StrMaxCpy( &dst[ dstLen ], src, maxLen - dstLen );
return dst;
} /* StrMaxCat */
* Copies the source to the destination, but makes sure that the
* maxLen.
* @param dst (out) Place to store the string copy.
* @param src (in) String to copy.
* @param maxLen (in) Maximum number of characters to copy into @a dst.
if ( maxLen < 1 )
* There's no room in the buffer?
return "";
if ( maxLen == 1 )
* There's only room for the terminating null character
dst[ 0 ] = '\0';
return dst;
* The Visual C++ version of strncpy writes to every single character
* of the destination buffer, so we use a length one character smaller
* and write in our own null (if required).
* This allows the caller to store a sentinel in the last byte of the
* buffer to detect overflows (if desired).
strncpy( dst, src, maxLen - 1 );
if (( strlen( src ) + 1 ) >= maxLen )
* The string exactly fits, or probably overflows the buffer.
* Write in the terminating null character since strncpy doesn't in
* this particular case.
* We don't do this arbitrarily so that the caller can use a sentinel
* in the very end of the buffer to detect buffer overflows.
dst[ maxLen - 1 ] = '\0';
return dst;
} /* StrMaxCpy */
* Usage
void Usage()
fprintf( stderr, "Usage: sertest [option(s)]\n" );
fprintf( stderr, " Download a program via serial/i2c\n" );
fprintf( stderr, "\n" );
fprintf( stderr, " -b, --baud=baud Set the baudrate used\n" );
fprintf( stderr, " -d, --debug Turn on debug output\n" );
fprintf( stderr, " -h, --help Display this message\n" );
fprintf( stderr, " -p, --port=port Set the I/O port\n" );
fprintf( stderr, " -v, --verbose Turn on verbose messages\n" );
} // Usage
