Software => Software => Topic started by: cybcode on August 19, 2007, 06:13:39 AM
I have a few questions about delay_cycles (SoR_Utils.h) and delay_us (timer.c):
1. How do you know exactly how long a cycle in delay_cycles and delay_us takes? (just curious)
2. If the program is compiled with different optimization settings, isn't it possible for delay_cycles or delay_us to take a different number of CPU cycles per iteration?
3. How come an iteration in delay_us takes 5 CPU cycles (according to the comment), and an iteration in delay_cycles takes about 0.992/23 = 0.043 ms (according to the comment), which, if I understand correctly, should be 43 CPU cycles, if the frequency is 1.0Mhz? Am I mistaken to assume that if the frequency is 1.0Mhz then a single CPU cycle takes 1e-6 seconds, or 0.001 ms?
4. If the frequency in Atmega8 is 1.0Mhz by default, according to one page in the site(http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml), then why is it defined by default as 3.69Mhz in global.h?
Thanks!
I put it on an oscilloscope and measured the exact time. You can also use a multimeter Hz function, flash an LED and time it, or just plain guess until your servo works.
No. A clock cycle is a hardware event. Also, my delay_cycles code will not work with optimization turned on because the compiler will think it doesnt do anything but waste cycles, thereby removing it.
I dont really understand the clock on the microcontroller enough to give you a good answer . . . I determined all this with experimentation. I defined a cycle as the minimum amount of time it takes for the microcontroller to process an empty while loop. This is what really matters to a programmer, anyway. If I remember correctly, PIC's take I think 4x more clock cycles than AVR to process the same event.
That number is only used by AVRlib stuff . . . for my $50 robot that number isnt used and so I just left it as default. If you were to use the UART or a timer interrupt than the number will be important to get right.
I hope that helps . . . Im no expert on clock cycles . . . but Im learning!
