Software => Software => Topic started by: Invicta on July 27, 2010, 06:15:51 PM
I load programs to my Axon2 using the supplied USB cable connected to UART-1. Is there any reason I could not replace the cable with a Bluetooth link?
If I can do the above and load up a program that uses UART-1 to transmit data to the Windows Terminal program via Bluetooth as well, will this cause problems when I want to load up another program?
I presently use UART-2 with a Bluetooth link to send data to the Windows Terminal Program and I want to free up UART-2 for other uses.
A very good [unsolved] question:
http://www.societyofrobots.com/robotforum/index.php?topic=3899.0 (http://www.societyofrobots.com/robotforum/index.php?topic=3899.0)
@Admin
OK, forget about using a Bluetooth link to upload programs via UART-1, too many issues.
Is UART-1(USB) limited only to uploading programs via the supplied USB cable? Could I use it for anything else; such as sending data back to my computer via a USB Bluetooth dongle? If I do this will it cause problems when I want to upload another program using the supplied USB cable?
Yeap, you can use USB to send/receive data.
The only 'problem' is that you need to remember to disconnect Hyperterminal before using the bootloader, then reconnect Hyperterminal when done.
