Software => Software => Topic started by: massi on June 07, 2007, 08:34:36 AM
Problems with ir sharp gp2d02
Hi i have an ir sharp sensor a gp2d02 (digital output; range: 4 -80 cm) i tried all the ways to make it work but in vain
in fact; i'm using a pic 16f84 ( using mplab) i'm following exactly what is written on the datasheet in terms of temporisations but it is not working.
it is for a robotics application: i need a led to switch on when the obstacle is at a distance lesser than 40cm.
help me please it's urgent
here is my source code
; gpd202 *
;CK_GP2: clock
;Vout_GP2 : output of gp2
;cgp2 : byte where the datas are kept
GP2D02
movlw D'7'
movwf cT
bcf CK_GP2
call PDelay ; 80ms
bsf CK_GP2
call tempo
bcf CK_GP2
btfsc Vout_GP2
bcf cGp2,0
btfss Vout_GP2
bsf cGp2,0
call tempo
bsf CK_GP2
call tempo
turn
rlf cGp2,f
bcf CK_GP2
btfsc Vout_GP2
bcf cGp2,0
btfss Vout_GP2
bsf cGp2,0
call tempo
bsf CK_GP2
call tempo
decfsz cT,f
goto turn
call tempofin ;1.6ms
return
; PROG. *
start
call tempo
call GP2D02
bcf STATUS,C
movf cGp2,w
sublw D'110'
btfsc STATUS,C
goto notgood ; positive result ==> cGp2 < 110 then none critical distance
goto good ; negative result cgp2 > 110 then dangerous distance
notgood
bcf myled
call temporisation ; just to have time to see if it detected something or not
goto start
good
bsf myled
goto start
END
thx
always do a google search first:
rangefinder basic source code (http://www.google.com/search?num=30&hl=en&safe=off&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=YYj&q=sharp+rangefinder+basic+source+code&btnG=Search)
on the first page there is source code:
http://www.hobbyrobotics.org/index.php?title=GP2D12
also, to help us debug software, you must:
- Tell us what microcontroller you are using.
- Tell us what programming language you are using.
- Tell us what compiler you are using.
- Comment your code!!!
- Define 'not working' - is smoke rising? is it not printf'ing? is it compiling? voltages arent correct?
Its kind of like me saying 'why is my robot not working?' and then posting uncommented code - we need more info! Let us know what you have tried so far. ;D
