Software => Software => Topic started by: jkerns on August 28, 2012, 11:53:09 AM
OK, I know, just use AVRDUDE. Thanks. But...
I wanted to change fuses to change the clock frequency - load up AVR studio, tell it I have the AVRISP MK II, ATMEGA32 chip, try to connect and I get "Connect failed, select AVR programmer".
The light is green, I get a green flash when I plug in the USB...
Now, I try avrdude to see what happens.
That seems to work. I get lights flashing and the following (as an example)
M:\>avrdude -p M32 -c avrispmkii -P usb -v
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
Using Port : usb
Using Programmer : avrispmkii
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200067118
AVR Part : ATMEGA32
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 4 10 64 0 no 1024 4 0 9000 90
00 0xff 0xff
flash 33 6 64 0 yes 32768 128 256 4500 45
00 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0
0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
Hardware Version: 1
Firmware Version Master : 1.10
Vtarget : 5.0 V
SCK period : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e9502
avrdude: safemode: lfuse reads as E1
avrdude: safemode: hfuse reads as 99
avrdude: safemode: Fuses OK
avrdude done. Thank you.
So, it seems to me that the device is hooked up OK and capable of talking to yea olde chip.
Now, I could just use avrdude to change the fuses, but it makes me nervous to work with the raw hex - it's been 20 years since I used to do that stuff... And it's bugging me that I can't get the AVR studio to work.
Any guess about what I'm doing wrong?
Oh, and I've tried two different AVR ISP mk II programmers.
Have You tried AVR Studio 5 or Atmel Studio 6?
All AVRDUDE is telling you is that your computer can talk to the AVRISP. You've told it on the cmd line that its an ATMega32 chip, and it has found the programmer.
Don't think it proves that the programmer is talking to the chip.
Looks like you're using AVRDUDE on a PC - in which case it will have been compiled with its own libusb.dll support. It could be that AVRStudio can't find the libusb drivers or you have installed over the top of the ones that AVR Studio installs.
See http://mightyohm.com/blog/2010/09/avrisp-mkii-libusb-drivers-for-windows-7-vista-x64/ (http://mightyohm.com/blog/2010/09/avrisp-mkii-libusb-drivers-for-windows-7-vista-x64/)
Thanks.
I tried installing AVR studio 6, uninstalling the driver for the AVRISP mkII, letting it re-install - no luck. I assume that it must be that AVR is using a different driver that is not actually connected to the programmer.
I guess I'll just work with winavr / avrdude for now. That has worked for me before for programming this chip. I just need to track down the bit by bit data on the fuses...
Thanks for the suggestions.
