Electronics => Electronics => Topic started by: robonoob on December 13, 2007, 12:35:06 PM
so...can i modify a servo(to a 360 rotation) without a servo controller?
Yes, if you take out the pot and replace it with 2 2.5kohm resistors in series, with the middle point connected where the middle of the pot was and the the ends of the resistors connected where the sides of the pot were.
Check out google, for example: http://www.acroname.com/robotics/info/ideas/continuous/continuous.html (http://www.acroname.com/robotics/info/ideas/continuous/continuous.html)
also this
http://www.instructables.com/id/modify-the-hitec-hs-325-servo-for-continuous-rotat/
i just found this video from youtube... http://youtube.com/watch?v=CtLN8BoMIlQ he makes the servo to turn(by connecting it to a battery...) and then turns the pot until the motor stops... but how does it turn again when he reassembles everything?
he connected it to a receiver which sent out the 1500ms pulse
and that means? :D
the receiver that recieves the signals from the remote centered the cervo because teh joystick was centered
umm okei then...
