digital or analog servos?
richard mackie:
hey everyone im new to the forum Im a freshman in college and well the end of the semester is near so i will be using my month off to hopefully build my first robot, nothing too complicated and simliar to the 50 dollar robot.
My question is should I go with digital or analog servos? I have never worked with either of them and have read that digital use up batteries faster and are more expensive but also have a better torque and precision. Analog are just cheaper and use the batteries up slower. I want something with power that i can use in the future projects such as this
http://homepage.mac.com/sigfpe/Robotics/equibot.html
digital are most expensive but are they worth the investment?
Robotboy86:
Short answer:
No. Digital servo's just roll a few different systems into a nice package for you.. a good deal of servo usage doesn't need to be that percise.
Long answer:
Yes! They are indeed worth the money if you need all of there features.. for example I am currently working on a hexapod. My hope? That it can run in the end. Yes, like an animal loping across the plain kind of deal.. but it must first learn to stand, then crawl, then walk, then move, balance, and then to run. So for now, I am buying a few 1/4 size(bigger then micro) servo's and the robot will only have 1 dof per leg. The leg joint itself. Where it meets the base and all. I will be building from there and moving into other fields(such as balance) as I need to.. but not until far into the future will I really even want digital servo's(if at all). For now, analogs are great.. and even if I end up not using them on this one, I will on another.
richard mackie:
thanks ill just stick with the analogs for now
Admin:
My advice is get the servos that match the specs of your robot.
Don't spend extra for features you don't need :P
Although, you may want to get better servos on the assumption you will need them in future robots you build . . .
Fredrik Andersson:
Even if one for sure will need better servos in the future it's not worth buying them now if you won't need their full capability yet. The prices on servos are falling really fast, so you will probably get off cheaper if you buy them when you really need them.
Navigation
[#] Next page
