Electronics => Electronics => Topic started by: airman00 on October 24, 2008, 11:05:05 AM
http://www.adafruit.com/index.php?main_page=product_info&cPath=17&products_id=123 - $7.50 .
The cost is a bit high but I assume the price will become lower in the coming months.
ATmega8 - a chip with 8K of flash memory and 1K of RAM. Then AVR released the ATmega168, a drop-in replacement with 16K of flash and 1K of RAM - a really big improvement! Now there is the ATmega328 with 32K of flash and 2K of RAM. Basically its got the capacity of an ATmega32 but in a slimmer package. These chips are notable for their ability to drop-in replace the ATmega168.
Time to upgrade the $50 Robot controller ;)
Its an upgrade for the 168P
http://www.atmel.com/dyn/products/product_card.asp?part_id=4198 (http://www.atmel.com/dyn/products/product_card.asp?part_id=4198)
http://www.atmel.com/ad/picopower/ (http://www.atmel.com/ad/picopower/)
ATMEGA328P-PU-ND
$2.66 each on digikey.com
but package size of 14
ATMEGA328P-PU-ND
its out of stock by digikey
Hmmm looking at the specs . . . the only difference is twice the memory as the 168.
airman00, I remember you mentioning that you are making a product with the 168 . . . here is your chance to double your memory as a way to outdo the Arduino. ;D
have a DIP socket , so I can put either the 8,168,or 328
got two ATmega328P's in the mail from mouser today when I got home.
Dropping them in my Roboduino, and my $50 robot board.
;D
hmmm, what to do...it may just be late and i'm tired and i don't see something i missed:
Compiling: 50_robot_sharp_IR.c
avr-gcc -c -mmcu=atmega328p -I. -gstabs -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=50_robot_sharp_IR.lst -std=gnu99 -Wp,-M,-MP,-MT,50_robot_sharp_IR.o,-MF,.dep/50_robot_sharp_IR.o.d 50_robo
t_sharp_IR.c -o 50_robot_sharp_IR.o
unknown MCU 'atmega328p' specified
Known MCU names:
avr2
at90s2313
at90s2323
at90s2333
at90s2343
attiny22
attiny26
at90s4414
at90s4433
at90s4434
at90s8515
at90c8534
at90s8535
at86rf401
attiny261
attiny461
attiny861
attiny13
attiny2313
attiny24
attiny44
attiny84
attiny25
attiny45
attiny85
avr3
atmega103
atmega603
at43usb320
at43usb355
at76c711
avr4
atmega8
atmega48
atmega88
atmega8515
atmega8535
at90pwm2
at90pwm3
avr5
atmega16
atmega161
atmega162
atmega163
atmega164p
atmega165
atmega165p
atmega168
atmega169
atmega169p
atmega32
atmega323
atmega324p
atmega325
atmega3250
atmega329
atmega3290
atmega406
atmega64
atmega640
atmega644
atmega644p
atmega645
atmega6450
atmega649
atmega6490
atmega128
atmega1280
atmega1281
at90can32
at90can64
at90can128
at90usb646
at90usb647
at90usb1286
at90usb1287
at94k
avr6
atmega2560
atmega2561
avr1
at90s1200
attiny11
attiny12
attiny15
attiny28
50_robot_sharp_IR.c:1: error: MCU 'atmega328p' supported for assembler only
I think I have to upgrade some libraries...bah i'm too tired, another day...
Double flash but also double EEPROM.... :P
yeah i ended up upgrading my winavr last night to the december 2008 version, but then I got some other syntax errors, like it didnt recognize the registers or something
The Arduino guys worked the kinks out and Arduino version 11 is compatible with ATmega368. You can buy the microcontroller with the bootloader uploaded from a few sites that sell Arduino stuff. Take a look at the Arduino forum, there is no reason to reinvent the wheel... (I mean struggle to solve a problem others did allready...)
Oh but this is for AVR Studio 4
And Arduino is based on AVR GCC... and they are using some of the avrlib... and AVRdude to program the microcontroller... So maybe, maybe it will worth a look... I looked when they were talking about it, and there is some info that may help you. I don't remember exactly what was it, and I'm sorry I don't have the time to dig it up.
Gettin these errors now after updating the winavr to 20081205, at least it recognized the mcu now. all UART errors. Would the 328 have different register names?
Compiling: uart.c
avr-gcc -c -mmcu=atmega328p -I. -gstabs -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=uart.lst -std=gnu99 -Wp,-M,-MP,-MT,uart.o,-MF,.dep/uart.o.d uart.c -o uart.o
uart.c: In function 'uartInit':
uart.c:52: error: 'UCR' undeclared (first use in this function)
uart.c:52: error: (Each undeclared identifier is reported only once
uart.c:52: error: for each function it appears in.)
uart.c:52: error: 'RXCIE' undeclared (first use in this function)
uart.c:52: error: 'TXCIE' undeclared (first use in this function)
uart.c:52: error: 'RXEN' undeclared (first use in this function)
uart.c:52: error: 'TXEN' undeclared (first use in this function)
uart.c: In function 'uartSetBaudRate':
uart.c:93: error: 'UBRRL' undeclared (first use in this function)
uart.c: In function 'uartSendByte':
uart.c:119: error: 'UDR' undeclared (first use in this function)
uart.c: At top level:
uart.c:230: warning: 'SIG_UART_TRANS' appears to be a misspelled signal handler
uart.c: In function 'SIG_UART_TRANS':
uart.c:239: error: 'UDR' undeclared (first use in this function)
uart.c:258: warning: 'SIG_UART_RECV' appears to be a misspelled signal handler
uart.c: In function 'SIG_UART_RECV':
uart.c:263: error: 'UDR' undeclared (first use in this function)
make: *** [uart.o] Error 1
Build failed with 11 errors and 3 warnings...
