Mechanics and Construction => Mechanics and Construction => Topic started by: brijesh on June 15, 2007, 08:10:37 AM
In RC cars a small toe-in angle between 0-3 degrees is used to increase straight line stability. How about using the same concept with differential steering robots, with 2 wheels and a caster?
Has anyone tried it?
Here is link which explains Toe, Camber and Caster angles of wheels.
http://www.ozebiz.com.au/racetech/theory/align.html
With a Toe-In angle there will be some scrubbing of the wheel and loss of power. Question is how much will it help in keeping the robot going straight with a diff-steering?
Brijesh
well when the robot starts going backwards it turns into toe out.
Most of the RC car toys i have dismounted the stearing mechanism is driven by magnets. Just magnets turning + and - by power controlling what way its going to turn, i dont know if that got anything with this to do tho.. :P
ed1380,
mm...true, when it goes in reverse it becomes Toe-Out. Looks like I have to experiment a little to figure out if Toe-In has any positive effects.
sotu,
By RC cars I meant hobby grade RC cars. In hobby RC cars steering mechanism is well designed with lots of features for tuning.
Brijesh
that dosent apply to high proformance rc cars, the onroads use toe in, toe out, and camber as a tuning aid to improve the handling. they steer with a hobby servo and have bellcrank or akerman (sp) steering. very complex. great learning tool for dampning and suspension geometry.
ok, toe in is worthless on a robot unless your going at 20+ mph ( hobby rc go between 20 to about 50 or 60 on average) and are racing on a track wear hundreths of a second matter.
edit, sry didnt read the last post
