Electronics => Electronics => Topic started by: frank26080115 on November 25, 2007, 06:33:55 PM
Actually, I'd like to build a small 3D CNC milling machine, but I want to use as little number of pins as possible, so if I multiplex the common pin on all three motors, I can use 7 pins on my MCU instead of 12. Also I only need 7 MOSFETs to drive all the steppers.
But then, I can only use one motor at once and I lose a bit of accuracy.
Or should I use two serial to parallel 74HC595 latch shift registers? It'll be more of a pain in the ass but I'd maintain all control. I'd need 12 MOSFETs, but only 4 MCU pins.
I may be totally wrong about this, but I thought 4 lead stepper wires don't have a common wire (since they're only bi-polar). On a side inquiry, if it would work, why would it reduce accuracy?
How much current do you need?
Why not get stepper driver? Something like this would only need 2 pins/stepper:
http://www.sparkfun.com/commerce/product_info.php?products_id=8368
or (scroll halfway):
http://www.active-robots.com/products/motorcon/
but i can use any half bridge IC... I have L298HNs I can use.
