Mechanics and Construction => Mechanics and Construction => Topic started by: Razor Concepts on January 31, 2010, 02:23:48 PM
Does anyone know where I can get connectors and hosing to fit on the threads of 2-liter bottles? I can only find those little vortex in a bottle connectors, but those don't really help.
Don't know if any's available (besides the vortex ones which might be cut to work), but why not just drill a hole and mount a hose connector yourself? (That's what I'd do).
Hmm, I guess I could do that. I suppose these fittings could handle up to 80psi?
pends on how well u cut the hole and what connector u use
As they're used with air compressors up to more than 350psi, the fittings should not be a problem.
A "rubber" gasket on either side and perhaps a suitable shim/disc to give it more hold on either side as well, will make sure either the bottle or the treads of the capsule, will be the first to give in.
http://www.technobots.co.uk/acatalog/Shop_Front_Model_Valves___Cylinders_144.html (http://www.technobots.co.uk/acatalog/Shop_Front_Model_Valves___Cylinders_144.html)
bottem of that page
also have you checked out the rex's robot challenge guide? it has this in it
