Electronics => Electronics => Topic started by: Joker94 on December 27, 2009, 07:04:04 PM
Hi every one
i want to connect an atmega8 and an atmega 168 for a project i may end up doing and want to know what i need to do for this to happen.
I2c, Uart?
Joker94
Well, it depends on the project... What do they need to do...
I2c could be useful because it doesn't use up uart...
What are they going to be doing?
Why do you need 2? I'm betting there is a better solution than using two microcontrollers.
mostly i am just curious. But if i did end up doing it would it be possible to have upto 16 servos in a program?
And another quick question, what are the possible uses for the left over ports on mcu's, eg. D ports are used for the servos, c ports are used for the sensors, what about the B ports and the other ports not being used. More servos, LEDs?
Thanks Again
Joker94
You dont have to use each port for each things, there are 8 channels on each port and each channel can do different things. So D0 through D3 can drive servos, and then I can make D4 through D7 drive LEDs.
Also, if you were doing this because of the lack of servo ports, why not get an I2c/UART servo controller?
Well if i caan connect another mcu throught i2c or uart to my main mcu to get extra servo and sensor ports would be ok for now.
Would i be able to connect them via UART just be connecting then with 2 wires. Atmega8 tx to 168 rx and 8rx to a 168 tx.
thanks very much
Joker94
You can use 2 I/O lines for synchronous comms, one line for clock and the other for data and then you just have to write the routines for sending and receiving.
so connecting them by tx and rx will work.
Thanks For that
Joker94
