Software => Software => Topic started by: junior000 on February 20, 2008, 12:45:58 PM
hi,
i am using 18f4550 and c18 compiler.one sensor is connected to the port E0.motors are coneected to rc1 rd0 and rd3 rd4.
problem statement:whenever the sensor detects a black line or switches off, integer i has to increment by 1(all other times the sensor is high).
PATH:black tapes are arranged horizontally with gap of 20 cm on white surface
here goes my program.......
define an PORTEbits.RE0
void main()
int i=0;
TRISE = 0b00000001;
TRISC = 0;
TRISD = 0;
while(1)
while(an==1)
PORTC = 0b00000000; //run motors forward
PORTD = 0b00001001;
if(an==0)
i++;
while(i==3)
PORTC = 0b00000000; //turn left
PORTD = 0b00000101;
some delay;
i=0;
problem:the bot is running properly.....but it is not responding to the integer i(the direction is not changing)
should i use local or global variable???
should i specify "unsigned" int i???
Are you sure your variable 'an' ever changes to 0?
Also if an starts out as 1, then this is an infinite loop:
while(an==1)
PORTD = 0b00001001;
This is solved in a PM. The code simulates fine - its a problem with either sensor input or lack of power.
Hey Junior000, Im not getting on your back or anything but if you have a problem thats resolved you really should post a solution for other people that have the same problem
yeah..i should have posted this earlier
the problem was with the power supply.the bot is working fine.
