General Misc => Misc => Topic started by: izaktj on January 18, 2008, 03:53:08 AM
Title: My $50 Robot
Post by: izaktj on January 18, 2008, 03:53:08 AM
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/servocity.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/digikey.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/radioshack.jpg)
$17.98
$11.03
$47.14
____
$76.15
Did I miss anything or is there a site with lower prices?
How can I make the transaction safer?
Title: Re: My $50 Robot
Post by: SmAsH on January 18, 2008, 04:04:43 AM
hmm...well if you want really cheap prices you can check out www.futurlec.com they have quite good prices.
but when your searching it doesnt come up with very good results. so try using the item type. eg. instead of 120ohm resistor type resistor and select it from the list that appears. hope this helped you
~smash
Post by: izaktj on January 18, 2008, 04:17:50 AM
~smash
lol
thanks
Post by: SmAsH on January 18, 2008, 04:46:13 AM
lol? i dont see what was funny about my previous post. also you cant really make out the pic much....
~smash
Post by: izaktj on January 18, 2008, 06:05:22 AM
~smash
Sorry, I meant no disrespect. lol was for the trickiness of the site you mentioned.
Post by: SmAsH on January 18, 2008, 06:39:51 AM
naa man i was only joking XD im so immature sometimes ;D
Post by: garriwilson on January 18, 2008, 08:50:07 AM
Let me guess Smash,....you are... 12?
I can make out everything except the digikey cart. If you could just copy and paste each one to here and make a list.
Post by: izaktj on January 18, 2008, 10:05:43 AM
Sure, I'll fix it in a minute
Post by: izaktj on January 18, 2008, 10:09:14 AM
IC REG POS 5V 1.0A 4% TOL TO-220 $0.49
ATMEGA8-16PU-ND    IC AVR MCU 8K 16MHZ 5V 28DIP $3.66
ED3128-ND    IC SOCKETS 28PIN MS TIN/TIN .300 $1.68
CAP 220UF 16V ELECT SMG RAD $0.28
CAP .1UF 50V 20% CER AXIAL $0.13
CONN HEADER 36POS .100 VERT TIN $3.36
RES 340 OHM METAL FILM .40W 1% $0.95
RES 1.62K OHM 1/4W 1% METAL FILM $0.49
LED 3MM ALGAAS RED CLEAR $0.19
PROGRAMMER AVR IN SYSTEM $35.91
Subtotal   $47.14
Post by: izaktj on January 18, 2008, 10:40:36 AM
Now I need to purchase a soldering iron, can I find one of those at my local wal-mart?
Post by: ed1380 on January 18, 2008, 04:11:48 PM
if you're going to be soldering a good bit. even after you've done teh $50 robot then get a good soldering iron. invest just like you did with the $30 programmer.
another option is to get the $35 arduino from sparkfun. you'll just need so solder on some header pins, and you wont even need the $36 programmer. just a usb b cable
if you do get the aurdino, the source code might need to be changed a bit to use diferent pins
Post by: SmAsH on January 18, 2008, 04:17:19 PM
yes it is better to invest if your going to using it alot. i did and my soldering iron has lasted me 6 years still working fine today :)
Post by: ed1380 on January 18, 2008, 10:04:17 PM
op sorry for hijacking your thread.
a thing i'd like to add.
the battery seams pretty expensive. you might want to look around for a better deal.
you can get a 9.6v bat w/ charger for $20 at walmart or toysrus
Post by: SmAsH on January 18, 2008, 10:31:37 PM
yea i was starting to wonder about that. then i thought it might come with charger.....
that answers my question....
~smash
Post by: airman00 on January 19, 2008, 07:36:39 PM
umm Smash didn't you say you are 12  now   .............
(http://www.yeshotelrome.com/hotels-accommodation/wp-content/uploads/2007/07/pinocchio.jpg)
Post by: SmAsH on January 19, 2008, 08:17:40 PM
yes and no thats not a lie
EDIT: yes i got it for my 7th b'day...my birthday is in 12 days woooot
Post by: airman00 on January 19, 2008, 08:24:28 PM
ok whatever you say
but Smash you are avoiding my question , DID YOU BUILD A SONAR BOT. Actually I really  need working code or pseudo code
Post by: SmAsH on January 19, 2008, 08:34:51 PM
yes i did parcially. i didnt get to the programming stage! god. i was still testing if tracks worked when it fell in the pool! >:(
Post by: ed1380 on January 19, 2008, 08:36:02 PM
whats with it now?
how about a pic of it?
IIRC your camera phone can do 1200x800
Post by: cooldog on January 19, 2008, 08:38:33 PM
hold one man
sorry about the comment no offence meant i was just kinding around
Post by: airman00 on January 19, 2008, 08:43:46 PM
OK smash , thanks for your honesty , thats what I like around here!  ;)
basically you have a tank chassis  without sensors or anything
what  programming language do you use? ,out of curiosity , I tend to use assembly and BASIC for microcontrollers
and by partially you mean have you interfaced the sonar sensor yet, thats the part I am concerned about...
Post by: SmAsH on January 19, 2008, 10:31:27 PM
smashes half complete robot? jk lol vid of tracks (home made) www.freewebs.com/smash-robotics/sonarbot
lol
~smash
Post by: airman00 on January 19, 2008, 10:35:48 PM
The link is    http://www.freewebs.com/smash-robotics/sonarbot.htm (http://www.freewebs.com/smash-robotics/sonarbot.htm)
and Smash , the treads are on soooo loosely , they will come off in about 5 minutes, I doubt that they can drive the bot at all in that condition. Buy a tank toy and hack it with tracks attached , or don't use tracks at all!
Remember , think of what sensors you will add to truly make it a robot and not a chassis
Post by: SmAsH on January 19, 2008, 10:44:36 PM
yea im trying to find a toy with tracks that has enough space in the middle for the internal stuff like motors. will update if i find anything. and Eric do you have msn? or skype?
Post by: ed1380 on January 19, 2008, 10:48:00 PM
you dont need alot of room in the middle. you can build up. just have batteries low in teh middle
Post by: SmAsH on January 19, 2008, 10:51:41 PM
lol ill go find a toy "made in china" tank.
Post by: izaktj on January 21, 2008, 01:25:38 AM
lol
Well guys thanks for the help =P
so the arduino would be better than the programmer?
I alredy have  usb b cable =]
http://www.sparkfun.com/commerce/product_info.php?products_id=666
Title: lol
Post by: SmAsH on January 21, 2008, 01:33:02 AM
its made in italy...oh well. and yea theyre good if you dont have a serial port.
~smash
Title: Re: lol
Post by: izaktj on January 21, 2008, 02:23:30 AM
~smash
My laptop has a serial port.
Post by: Admin on January 25, 2008, 07:50:39 PM
two things:
don't hijack threads
focus on making robots!
(just trying to keep the forum high quality ;D)
Post by: izaktj on May 16, 2008, 08:03:03 PM
Hi guys, well it took me moths to order the stuff xD
I was busy this last semester of high school.
Anyway, I've ordered all the parts to build it.
Expect them to arrive May 21th.
I'll keep you updated d=
Post by: izaktj on May 23, 2008, 09:28:17 PM
Parts have arrived! =D
Now I need to buy:
- Soldering iron
- Batteries and charger
- Solder roll
- Multimeter
Post by: izaktj on May 25, 2008, 02:12:40 PM
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301671-1.jpg)
Post by: izaktj on May 25, 2008, 03:28:29 PM
Wheels have been built
I did go garbage seeking as admin suggested d=
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301672.jpg)
Process:
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301673.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301674.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301675.jpg)
Post by: izaktj on May 25, 2008, 06:34:25 PM
OK, the robot chassis has been made d=
I cut a 3" x 6" rectangle of foam board. I also used a water bottle as the tutorial says.
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301676.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301677.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6301678.jpg)
Post by: izaktj on May 25, 2008, 09:06:10 PM
So, any thoughts or suggestions?
Post by: airman00 on May 26, 2008, 08:51:43 AM
mmmm
look for a cooler chassis once the robot works,
use parts and cases that are just lying around....
Post by: izaktj on May 26, 2008, 10:20:11 AM
mmmm
Post by: Admin on June 08, 2008, 12:11:15 PM
Yea my goal for the $50 Robot was to make a chassis extremely cheap and easy, requiring almost no tools.
Its to get people started.
But I expected no one to settle for my design, and hoped everyone would quickly upgrade after understanding the basics . . .
Post by: izaktj on June 11, 2008, 01:14:45 PM
Hey guys, sorry for not posting in a long time...
I'm still building it but I came to a problem. I think I screwed it up when soldering. I'd post pics but all come blurry...I don't know why my camera is a piece of shit.
Anyway, I'll try to take one shot as clear as possible.
Post by: izaktj on June 11, 2008, 07:39:16 PM
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6308010.jpg)
Here is it...
I soldered 2 rows together...=S
Post by: izaktj on June 11, 2008, 08:01:10 PM
Here a very big resolution
(http://i245.photobucket.com/albums/gg50/izaktj/S6308031.jpg)
Post by: izaktj on June 11, 2008, 11:35:18 PM
So is it way to screwed? =S
Post by: hazzer123 on June 12, 2008, 06:15:54 AM
You need to use a solder sucker or some solder mop to get rid of the excess.
Post by: airman00 on June 12, 2008, 06:41:38 AM
not at all, this happens all the time
follow hazzer's advice
you can use a solder sucker , desoldering wick, or even just melt the solder and while its melted push off the excess solder with a dentist pick or something
Post by: izaktj on June 12, 2008, 10:39:39 AM
Thanks a lot guys!!!  ;D
Post by: pomprocker on June 12, 2008, 10:56:37 AM
looks good so far!
i still need to post up pics of mine.
Post by: izaktj on September 18, 2008, 11:31:32 PM
OK guys I'm back at building this robot, I halted this project due to lack of knowledge and motivation. I entirely focused on bodybuilding (on vacation). So now that college has begun I have bought better tools, I was gifted soldering practice equipment (like 50 resistors for free lol and 2 boards)
Tomorrow will restart work on it ;)
Post by: izaktj on October 21, 2008, 10:58:44 PM
screw it i can't solder to save my life...
I'll try breadbording it.
Post by: izaktj on October 26, 2008, 06:01:33 AM
Progress!!   :D
After hours of analyze, searching and asking, I finally broke trough.
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6309075.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6309079.jpg)
(http://i245.photobucket.com/albums/gg50/izaktj/the50dlrobot/S6309080.jpg)
NOTE: The long wires are for the programmer.
I still need to add more stuff and build the sensors, modify the servos for continuous rotation or maybe use the ones I got on the sumobot.
