Electronics => Electronics => Topic started by: maceliz on July 26, 2014, 09:19:58 PM
I'm running two 24V 35amp motors with a Sabertooth Dual 25A 6V-24V Regenerative Motor Driver connected to a remote controller and it is working fine but after some minutes the motors stop, my assumption is the wiring is getting to hot as I can feel it and are not allowing the current to flow but I'm not sure.
If I wait some seconds the motors work fine again.
I'm using 12 gauges wires and planning to change it for 8 gauge wires?
Do you think I'm doing the right assumption or might be something different?
maceliz, something seems wrong with the above line(using 25A drive with 35A motor?)
do you have a model or part number for the motors your using?
Tommy
If you are running 35 amp motors through a 25 amp drive, it is likely that the driver is overheating and shutting down.
Too small wires will have a voltage drop across them and waste power and in the worst case melt the insulation, but they would not typically cause the symptoms you describe.
jkerns is right, the motordriver is going into 'thermal shutdown'.
Ideally, you should use a motordriver of 35 amps.
Another option is to run your motors at a smaller voltage, or PWM to no more than perhaps 70% duty. While the driver might not overheat anymore, the motors would have very reduced torque/rpm.
