Electronics => Electronics => Topic started by: otakis on February 03, 2008, 05:30:23 PM
hello,
i am from Greece and this is my first robotic project (great tutorial).
sorry for my bad english.
today i was constructing all electronics, but i don't understand the connections of the flat serial ICSP cable (in the female serial connector).
please help me!
thanks
I ask informations for this cable!
what information do you want? (please explain better)
the connections in the female serial connector (in the circle).
which cable correspond to which pin (10 cables to 9 pins)
Do you have a multimeter?
You can use the diode test to see which pins in the DB9 connecter go to which pins on the pin header connecter.
no, no...
i haven't serial cable...
i must construct this cable
the "cable" in that picture is the programmer. there are diferent ones. the one in the pic is ~$14 but you can get a better one for $30
i think he wants to make the programmer.
good luck with that. didnt work for me
The cable is not a simple rewiring of a connector. It has some electronics inside the big grey part of the DB9 port. It is still possible to make an equivalent of this cable, but it wont be as simple as i think you thought. ;)
i actually took mine apart once and it didn't seem like it would be that hard to make.
just for the record there is actually 10 parts of the programming cable, the 9 pin holes, and the outer rim make up the 10 pins.
thanks all for the responce
i found this http://www.olimex.com/dev/images/avr-pg1b-sch.gif (http://www.olimex.com/dev/images/avr-pg1b-sch.gif)
Thanks otakis, I was also looking for this :) will try first making the programmer, if it fails, then I will have to buy a programmer, which would be probably the AVRISP, but the Arduino is also under consideration, but with the fundamental question: can the Arduino be used to program ATmega** MCU's on the robot instead of on the Arduino board, but like the AVRISP / LPT programmers do?
