Electronics => Electronics => Topic started by: Magnum on August 05, 2008, 02:12:58 AM
hi, i have a motor driver 6-16V, 15A continuous, and a 12V motor, but the motor is 100m from the motor driver for application. From http://www.powerstream.com/Wire_Size.htm, i find that if i use 18AWG cable to connect the motor to the motor driver, it can cause 9V voltage drop. besides, the cable can overcome 2.3A only, then it is a waste of the high current motor driver. So do any one can give me some opinion to solve this problem? anyway, i really don't want to use a cable with large diameter..
What keeps you from moving the motor driver closer to the motor?
it is not i want because the robot should be as small as possible(in fact it has a motor only)..
How critical is this constraint? Can you elaborate more on your robot and why it needs to be so compact? Transmitting large direct currents over 200m of cable sounds like a bad idea...
I agree with the above, attempting to transmit that much current over a long distance at such a low voltage is just going to be a bad idea.
Use a superconductor. I saw one in a Siberian shop that was working at room temperature.
Is room temperature in siberia somewhere around 15 Kelvin? ;)
the robot is to inspect pipe, so i want keep it as small as possible. In fact i have another motor driver which can overcome up to 30V, but the cable still cannot overcome high current. So do you have any idea?
What is the diameter of the pipe you are inspecting? I think you need to come up with a more innovative mechanical solution that will allow your robot to carry its own battery and driver, or use a motor that takes far less current.
- Ben
Use that 18AWG 100meter cable to carry mains AC. Use fast acting inline GFCI breaker 10A or lower so that you don't blow your clients house fuses in case of a short. Attach your motor controller, transformer and rectifier to a small 'trailer' dragged behind your robot by a flexible strain relieved cable. Waterproof everything. Good luck.
