Mechanics and Construction => Mechanics and Construction => Topic started by: sotu on April 04, 2007, 03:41:24 PM
Can anyone PLEASE explain me (Easy) not to advancedso i cant keep up how to wire a battery to a Motor, but with driving it with a remote? So the motor won't rotate when i wire the battery to it but when i press the button on the remote?! ???
do you have a receiver on the vehicle? into the receiver does the power and ground, and from there the servo's and whatnots connect
The easiest way to do this is use modified servos as your motors, so all you have to do is hook the battery into and plug it into the r/c reciever. There is a way to do it with an motor, but that takes an motor controller or and ESC and also some servos and a some kind of a switch or a relay.
If your going to have a small robot go with the servo, if medium or large use the motor idea
I would say its medium, and i cant put in a servo now and remove the motor. I found it kinda confusion the way u explained how to connect the motor (9V) to a battery and at the same time connect it to the controller. It would be great if some of u could make a painting in "PAINT" where u draw all the pieces and show me with arrows where to connect the wires.
ed1380: right now i dont have a wireless control so i do not have a reciever i just got wires coonected directly from the controller to the motor(S)
No one knows how to make a battery stand on the robot and drive it without having the batteries in the control?
http://www.societyofrobots.com/robotforum/index.php?topic=713.0
Thank u soo much for posting that link to me..:D i was looking for something like that
A little mistake, the bot he maid (the link u gave me) the controller wasen't wireless..!
I believe Admin has a tutorial on his site about making wireless robots. I've not done it before myself, but some ppl have discussed it in the forums, you can probably find their threads around the forum, or try the search function.
Basically, if I'm not wrong (I'm a noob in this), you need a transmitter on your controller, and a receiver on your robot, and if you use servos the output of the receiver can be fed directly to it, since it's a PWM..
Sorry, I though you wanted it tethered.
For Rc- hack apart a rc toy, take controler board out out of the car and put it in the robot. cut the wires to the motors and solder your motors on. if you need more functions do it again, but you'll have to make a custom remote with both controler boards in it.(make sure they're diferent frequencies) 27, 49 are common.
or
buy remote with receiver with as many chanels as you want and plug the servo into the receiver(it should just plug in) then either use the servo horns to mechanically activate switches(best choice) or put a relay instead of the motor in the servo
But i dont have a servo i have a motor..:(
Ok, thanks. I got some big plans going on now for a 2 wheeled robot..:D
But everything youve said IS a RC car, am I right?
yes the plan is a R/C car. Yesterday i visited a Hobby store and talked to the worker about what u need for robots. He sold some pretty strong Motors but i coulden't buy them couse most lickely they would burn up my eletric card!
heavy duty h-bridge should do the job well
apparden?
Look up H bridge on google
I have done it now but i cant really understand what it is! ???
It's all about applying a voltage level into the H bridge to allow it to go forward, backwards etc
First link I got on google explained it really well
Give it another go
http://www.dprg.org/tutorials/1998-04a/
I got it a little better now but i cant wait uintil i know how to wire up an R/C controller to a robot making it a wireless controlled robot..!:D
if it's wiresly controlled by you it aint a robot.
trasmitter>>>>receiver>>>motor controller>>>>motor>>>wheel>>>>ground
buy as a set buy one that I really hope you're at least
fits your smart enough to get that
power needs
Google is your friend
So ure saying if a robot is wiresly controlled its not a robot? What about battlebots then?
IMO it's not a true robot, but everyone has their own opinion.
and that^ is mine.
It's a robot, it's just not autonomous. Yes, I don't know where my post went, I thought I was the first one to post. I explained all of this, I guess I forgot to press the [Post] button, oh well.
power needs
That's basically what I said. You have a transmitter that sends out a signal. In other words, it's your remote. This I would assume you are using RF. The signals from the pushing the buttons or moving the joysticks sends out and the reciever picks it up. This will take the signal and send it to your motor controller.
Motor controllers can get quite pricy $50 - $100 where I look. I would recommend you use DC motors with something connected to a gear box, so you get your torque and velocity you need. Also, you can use an H-bridge to control DC motors. I can't quite find the Dual H-bridge I use. I purchased it off of www.lynxmotion.com . A Dual H-Bridge allows control of two DC motors, which is probably what you are running. They can be bought pretty cheaply ~$20, and are very easy to use. Making your own isn't difficult either.
Following that it's just motors. There's a very good tutorial on this website with practially everything you need to know when considering wheels and motors.
Have fun
Ok thanks, if u could visit my "Need help!" In Electronics and help me out there it would be great..!:D
Im telling u here like im telling on many of my other posts. I may ask stupid and have hard to take in information. But isen't that what this forum is all about? Helping those who need help? And right now i need a lot of help when im making robots. Couse all knowledge about robotics i got is the one that i have thought my self to. I haven't any book/computer knowledge at all! :(
:) That's exactly why we're recommending some books and websites for you to read up in. While we may be able to answer the questions, the books/sites are very well-written and will probably do a much better job than we can. It's best that after you read a book or two, or as you're reading it, ask questions to clarify some of the stuff the books talk about.. That way, you won't have to wait for ppl in the forum to answer questions (since the books most likely can) and you can get clear direct answers for the stuff you need clarification in.
Also, besides the books that were listed in the other thread, I also recommend using wikipedia, google, and howstuffworks.com. I've personally learnt a lot from wikipedia and howstuffworks, and google has basically everything if you search hard enough (and you're lucky).. Howstuffworks tends to have very simple-to-understand descriptions, and lots of illustrations, which is very useful to get an understanding of a new topic. Wikipedia usually has more information, but sometimes that can be intimidating at first.
Good luck!
Thnx for all ure help, ure really helpfull..! ;)
By the way, there are some things to wonder that's not easy to google or search for on wikipedia!
Yeah definitely, and those are the sort of questions that you would do best to ask on the forum.. Generally, when you have a question, the first step should be google/wikipedia and all that, and if you can't find anything useful, or need more information, that's when the forum is extremely useful and helpful..
Somethings are hard to find on google, but it's very rare. This issue would be very easy to find on the web. If you start there, you don't have to wait for answers and it is probably someone who has a great deal of knowledge on the subject. The forums could help clean something up, but please look for it first. Most of this post is repeat after repeat of people trying to explain one subject. This website has a great deal of tutorials and you search for wireless remote tutorial or something and get thousands of results. It serves to find "How do I set up a wireless remote circuit". Wikipedia serves for more of the knowledge based items like asking "What is a wireless remote".
Most forums have searching google/wiki in the criteria for posting along with finding it in the previously posted topics in the forum. If you do end up doing this, then most will just boot you.
And the in 5 days this post took to get to the point it is now, you could be an expert on wireless controllers knowing what each part does. Don't be lazy...
Yeah it went from an normal topic to an hot topic on days..:P Anyway i got a sort of a manuel book for robots. I think it was called bonzana or something. It's saved on my computer now and i wil start reading it soon. It will take very long time to read through all of it because its an PDF file on over 700 pages.. :o
Good luck with the reading.
Not knowing english will make it hard, but it'll help with you learning english.
Thnx, i better get started then..:P
U got some answars for them then?
Don't cut and paste your questions to all threads, like this.
see it's anoying.
use google.
