Software => Software => Topic started by: rox2007 on January 14, 2008, 02:08:21 PM
Ok i followed the instructions in the modifying servos tutorial but i cant get the part where you stop the gears by moving the pothead.
I keep turning it left and right but it doesnt work.
Please help
move it slowly and make sure you are giving it the right pulse at the corerct oscillator setting
what exactly is the right pulse and oscillator setting for an atmega 168. i am passing 1.5ms on the internal 8Mhz clock
i turn and turn and turn. The speed just get's slower or faster. it goes from one extreme to another. fast to slow...slow to fast....theres no midpoint where it just stops
turn it very slowly and carefully
also try to give it 1.5ms @ 4mhz
what is your code ?
#include <avr/io.h>
//Define functions
void ioinit(void); //Initializes IO
void delay_ms(uint16_t x); //General purpose delay
void delay_cycles(unsigned long int cycles);
int main (void)
ioinit(); //Setup IO pins and defaults
while(1)
PORTC = 0xFF;
PORTB = 0xFF;
PORTD = 0xFF;
delay_cycles(35);
PORTC = 0x00;
PORTB = 0x00;
PORTD = 0x00;
delay_cycles(35);
//delay_cycles(500);
return(0);
void ioinit (void)
//1 = output, 0 = input
DDRB = 0b11111111; //All outputs
DDRC = 0b11111111; //All outputs
DDRD = 0b11111110; //PORTD (RX on PD0)
//************DELAY FUNCTIONS************
//wait for X amount of cycles (23 cycles is about .992 milliseconds)
//to calculate: 23/.992*(time in milliseconds) = number of cycles
while(cycles > 0)
cycles--;
that's my code. i was running at 8mhz and sending 1.5ms
which servo are you using?
HS-311, the ones recommended by the tutorial
I finally got it to work...Thanx alot
just as i was about to post this
http://www.instructables.com/id/modify-the-hitec-hs-325-servo-for-continuous-rotat/
Help people with the same problem, tell us what was the problem and how you fixed it.
well, i sent a 1.5ms pulse and ran my atmega168 at 4 mhz...and i rotated the pot until the gears stopped
at what mhz?
Since nothing else seems to be working, I used the OP's code but can't see where to change the frequency. I'm using AVR Studio.
at what mhz?
;D
at what mhz?
;D
to garriwilson
the 4mhz was edited in his post AFTER I replied ;)
i did, sorry about that
Oh my bad ;)
