General Misc => Misc => Topic started by: MaltiK on November 12, 2008, 05:05:36 AM
Is this possible to use a LDR on one microcontroller and a laser on another and when the laser hits the LDR 1's appear, and when it doesnt, 0's appear, does anyone know of a tutorial for this, its a very interesting subject.
I've done a project like this some years ago. But I transmitted analog signals instead of digital :o
It's pretty easy really. What I did before was I connect a laser pointer to the audio-out of a radio, and an LDR to the audio-in of an amplifier. I can't really remember the exact circuitry, but it was probably just some transistors for a bit of amplification etc.
This setting worked perfectly indoors. The furtherst I tested indoors was like 5 metres, and there was very little noise.
I tried to do it outdoors during a party we had, but the laser beam was too small to see from a few metres. I had a really hard time trying to focus the beam exactly on the LDR. Since a party is not a party without music, I had to cancel my experimentation after a few minutes of trying :(
I remembered seeing some tutorials on the web. There was this guy who managed to get his system working across the street. But he used a really big laser.
Google around!
Found this: http://www.instructables.com/id/Send-Music-over-a-Laser-Beam/
Sweet project man. How long did it take you to write the interface for it (translating data to laser and then back to data again)?
there is no software involved with the laser music system , its all in the circuitry
When I was in high school, I saw a LASER data transmission project. If you can imagine this, on the transmission side, the guy glued a piece of cardboard to a speaker cone on edge so that the cardboard stuck out perpendicular to the speaker cone. The speaker/cardboard were positioned so that it blocked the LASER beam when the speaker coil was not energized and unblocked it when the speaker coil was energized. He would send a "high-speed" data stream through the speaker. The receiver on the other end would then reproduce the data stream.
check these projects:
http://ronja.twibright.com/
http://www.modulatedlight.org/
they give a decent intro on the subject.
Its actually really easy . . . hook up the outputs/inputs to the Tx and Rx of your mcu UART, and you're done :P
If you have a $50 Robot completed and a pocket laser handy, I bet you can get it working in under 2 hours (including any soldering).
So, using the Laser as a transmitter, what do you use as a reciever, and LDR?
Depends on the wavelength of the laser :P
Unfortunately an LDR is too slow for a receiver, as it takes up to ~10 ms to change resistance. I *think* the pen lasers also emit infrared but not sure. Try using an infrared LED receiver and see if you get a signal - LEDs take only microseconds to detect a signal.
