Software => Software => Topic started by: SmAsH on April 14, 2009, 01:31:31 AM
im going to keep this as short and easy as possible. can the atmega8 be programmed with arduino code. i would still use avrstudio to upload it and everything but just use arduino language?
Yes you can. I'm using the $50 board but programming it with the Arduino software. To get the .hex file, you just write you program save and compile it , then press the upload to board button in the Arduino software. I'm using the mkII usb cable with avrstudio, so when I press upload to board, I get an error stating that no usb device found. But it then makes the .hex file you need to upload to you board via avrstudio.
awesome, thanks for that. ill try that later on.
