Software => Software => Topic started by: jsmoker on March 09, 2009, 09:41:04 AM
Title: Honestly, what am I missing?
Post by: jsmoker on March 09, 2009, 09:41:04 AM
I've done tons of projects with the dsPIC30F3012 and now suddenly I can't get a simple LED to light up.  I have a 5V power supply source with a .33uF cap on the source.  The dsPIC is set to use it's own oscillator.  Here's the code.  Maybe it's just a brain fart.  I should be able to do this in my sleep.
#include "p30fxxxx.h"
_FOSC(CSW_FSCM_OFF & FRC_PLL8); //Internal Clock routed through the PLL8
_FWDT(WDT_OFF);                 //Turn off the Watch-Dog Timer.
_FGS(CODE_PROT_OFF);
_FBORPOR(PBOR_OFF & MCLR_DIS & PWRT_OFF); //MCLR must be disabled to reprogram while using internal oscillator
void mdelay(unsigned int dcycle);
int main(void)
_LATD0 = 0;
int j = 0;
for(j = 0; j < 10; j++)
mdelay(3000);
while(1)
_LATD0 = 1;
return 0;
int i;
for(i = 0; i < dcycle; i++)
Nop();
Title: Re: Honestly, what am I missing?
Post by: paulstreats on March 09, 2009, 10:16:25 AM
do you need TRISD setting to output?
Post by: jsmoker on March 09, 2009, 10:24:34 AM
Yep! That was it.  For some reason I thought they defaulted to 0.
 Thanks!
