Electronics => Electronics => Topic started by: Joe on February 09, 2007, 12:19:54 PM
I was just wondering, since in your article about dc motors (http://www.societyofrobots.com/actuators_dcmotors.shtml (http://www.societyofrobots.com/actuators_dcmotors.shtml)) you say:
Place small microfarad capacitors across motor leads to extend motor life. This works really well with noisy and other el-cheapo motors, almost doubling motor life. However there is much less improvement using this technique with the more expensive higher end motors.
Would you consider $25 motors low end and thus would they benifit from a small capacitor accross the leads or would that do more harm than good? Here's the motors I have in specific: http://www.servocity.com/html/193_rpm_gear_motor.html (http://www.servocity.com/html/193_rpm_gear_motor.html)
nope, they should come pre installed but if you think they dont it wont hurt to put a capacitor across the leads. nothing will happen even if there is only one installed.
I bought two of those motors about 4 years ago. They are made by Hsiang Neng (Taiwanese company), and are just one step above 'el-cheapo.' A cap probably wont do much, but wont hurt. Id recommend putting one on.
What I hated about these motors is the mounting screw holes in the front (as you can see in the picture). The problem with the holes is that if you tightened a screw too tight in them, the motor jammed up and stopped working. I have no idea why they jam, but they do. This meant whatever I mounted to them had to be loose . . . I lost many a screw with these motors . . .
What I do like about them is that they are powerful and cheap.
