Electronics => Electronics => Topic started by: Half Shell on November 14, 2007, 09:58:16 AM
I've been seeing a couple of projects using motion sensing but they're only using a single sharp ir sensor. I've been playing with mine but can't figure out how to do motion sensing with a single IR sensor. Is there a trick I am missing?
http://www.societyofrobots.com/step_by_step_robot_step4.shtml
this uses motion to follow a object
If I were to do it, I'd have it scan and save the distances in an array.
Then I'd have it scan again.
Do a comparison between those two scans, and if it finds a big difference in values, you know something moved and the angle wrt the robot of that movement.
