Electronics => Electronics => Topic started by: jschoormans on April 19, 2007, 06:33:59 AM
Hi guys,
I need to remote control one servo motor. I have some old remote controls lying around, which I want to control the servo with (both clockwise and anti-clokwise) . Do you have any ideas about how I can make/ where I can buy a cheap IR receiver that is easy to connect to a servo motor??
The IR remote modulates a bit pattern on a 36kHz or 38kHz carrier, so you need an IR detector that can receive and demodulate the incoming signal - here's an example -
http://www.lynxmotion.com/Product.aspx?productID=194&CategoryID=49
We use a Vishay TSOP1738, which is functionally equivalent to the Sharp part.
After that, you'll need a processor or logic that can capture the bit pattern from the detector and convert that into servo commands. Here's an example of a similar project.
http://jap.hu/electronic/codec.html
ty, I think I can do that.:P
