Mechanics and Construction => Mechanics and Construction => Topic started by: EXOP1 on May 03, 2014, 10:32:20 AM
I'm working on a robotic arm with a shoulder, elbow, wrist and an end effector. My problem is to calculate the position and orientation of the wrist to reach a target and grab it. Can you help me, because I'm stuck :(
Google for "Inverse Kinematics."
The simple case is "Two-bone inverse kinematics" which is simple, and can let you decide the shoulder-elbow-wrist angle.
Also, if you don't yet understand linear algebra and 3D homogenous transform matrices, you'll probably need to learn that, first. Which can take a while -- I recommend starting with a 3D graphics primer or perhaps game physics simulation tutorial of some sort.
Thanks!
I found this page: http://onecuriousrobot.blogspot.se/2012/05/applying-inverse-kinematics-to-robot.html?showComment=1399137576745#c7835883238755448216 (http://onecuriousrobot.blogspot.se/2012/05/applying-inverse-kinematics-to-robot.html?showComment=1399137576745#c7835883238755448216)
Is that a good way to go? Maybe one can convert that from 2D to 3D.
