Electronics => Electronics => Topic started by: Andyspins on August 28, 2010, 12:32:45 PM
Where can I buy the little black headers that plug into the axon? Also, can A DC motor be used and treated like a servo?Thanks
Andyspins
Check SparkFun, DigiKey, Mouser for the connectors.
NO, you can not plug a DC motor directly onto the Axon output pins. A servo contains circuits to receive the low current pulse train (pulse width is translated into a servo position) from the processor and a high current motor drive circuit.
To run a DC motor you need a drive circuit. and much different signaling than a servo.
There is information on both servos and DC motor drivers in the SoR tutorials and articles.
Definitely read the full FAQ :P
http://www.societyofrobots.com/robot_faq.shtml#servo_motor (http://www.societyofrobots.com/robot_faq.shtml#servo_motor)
What is the exact name of it so I can serch for it?
add a .com after each name
Thanks but I meant the header not the site.
Yes, search those sites for header connectors, many to choose from.
Read this http://www.societyofrobots.com/electronics_wire_connector.shtml (http://www.societyofrobots.com/electronics_wire_connector.shtml)
Thanks that really helps!
