Electronics => Electronics => Topic started by: superchiku on March 12, 2008, 07:03:35 AM
i hope my bot would start working it has got a strange probelm in pwm ,
when it is tested with only the mcu in the breadboard , i get exactly same values of pwm but when used in the bot one is lower than the other i dont know why this is happening can u help
and yes both of my adc configurations are same so their corresponding pwm must be same so wat is the problem
mcu:atmega16
pwm channel used:oc0 and oc2
same prescaler and values
ADC:reference is AVCC and i have connected capacitor between aref and GND???
electrolytic or mylar capacitor?
mica capacitor electrolytic would just blow up
it works on the breadboard but on the main crcuit board it just gets mad doing strange things with pwm
and yes i have triple checked the connections
what is this main circuit board you're talking about? is it through hole, custom made pcb? etc.
main circuit board means the veroboard which is going to be attached to the bots
Is your ADC somehow controlling the PWM?
your cap isn't rated at the right voltage
yeap, you need a cap there too
thanks for the reply i found out the problem since iam using 2 different timers ,they are acting differently when connected to the veroboard i have adjusted the code accordingly and soon will be posting my bot's video
