Motor Torque Sanity Check
(1/1)
silo_xtreme:
Hi everyone,
I'm looking at a BLDC motor that has 4000 rpm, and provides 200W; which tells me that Torque is ~4.22 lb-in.
If i lower the rpm (via gears) to 100 rpm, I believe the theoretical Torque would be 4.22 lb-in * 40, resulting in a Torque of ~ 168.8 lb-in.
How would I know if the motor can actually support that amount of Torque?
Admin:
Well, if you use gears, you will take an efficiency loss. Without knowing your system, I'd say ~80%.
--- Quote ---How would I know if the motor can actually support that amount of Torque?
--- End quote ---
experiment :P
If you use my RMF calculator, you can determine torque by knowing velocity from an experiment. Or you can find the stall torque by forcing your motor from rotating.
Navigation
